Forum >TB6600 and Using 3.3v logic to handle INPUT
How to selectRobotics
userHead silver2row 2023-03-07 03:12:23 4275 Views8 Replies
I am using a beaglebone black to program the TB6600 to handle motor movement.
Does the motor driver allow for 3.3v logic input?
Seth
P.S. I read over the wiki and saw that it can be controlled via 3.3v but I wanted to make sure…
2024-01-08 20:46:20
Hello Again,
Do I use PWM or just GPIO peripherals for this device/driver? I think I have not fully understood how to interpret the electrical of it.
Seth
P.S. Please reply when you find time. I look here: TB6600_Stepper_Motor_Driver_SKU__DRI0043-DFRobot . What I find is a 5v logic board from DFRobot and two PWM channels and one GPIO but when I look in the source for the driver for the Arduino sketch, I think all three inputs to the driver are GPIO.
Is it that I need I/O or just output from the board to the TB6600?
userHeadPic silver2row
xingzhao.zhu wrote:
A stepper motor does not need PWM (Pulse Width Modulation) pins for control, and it cannot be controlled with a PWM signal. However, you can use the PWM pins as regular digital pins on your Arduino board, and they will work just fine for this purpose.
TB6600 Stepper Motor Driver - DFRobot
2024-01-12 20:34:10
2023-03-12 04:28:17
Okay. I finally figured out everything…
W/ gpiod…I was using it incorrectly.
W/ my lib, I was using it incorrectly. Everything works. Sorry to bother you guys/gals.
Seth
R2D2C3PO wrote:
Nice to see that.  Have fun.
2023-03-12 18:38:07
2023-03-11 19:16:54
Okay…the machine moves in one linear way but does not return to it previous position and cannot turn back. I think I have the hardware right.
Two PWM channels and one GPIO channel but I guess I am at a loss right now as to how to change the direction of the motion w/ the controller.
Seth
2023-03-07 13:51:42
Okay…I got it.
Thank you for being okay w/ me venturing into this forum.
Seth
2023-03-07 12:18:54
Also…
I have  no clue as to what chip is being used w/in this Motor Driver. I see the functions on it:
1. Enable or PWR/GND +/-2. Direction or GPIO +/-3. Pulse or PWM +/-
I think number 1. is PWR and GND and not GPIO but I am not sure.
2. should be a GPIO in my mind but it could be another technology. I see two PWM peripherals being used and one, I guess it is, GPIO…
3. Pulse has to be PWM in my thoughts…
I little guidance would be nice…I have this driver that is already written up for it but I cannot access the motor driver yet.
I am not sure if it is a permissions issue w/ Linux right now or the wiring for the connections.
Seth
P.S. If you have time, I would like your ideas on this effort I am approaching.
2023-03-07 03:17:39
https://wiki.dfrobot.com/TB6600_Stepper_Motor_Driver_SKU__DRI0043 is the site I am looking over that makes me think the input voltage signal can be 3.3v…
