Forum >wifi shield not respond
ArduinoGeneral
userHead peetscholsem 2016-07-06 12:17:22 18705 Views9 Replies
I have a problem with a wifi shield v3.0.
The arduino romeo v2.2 send a command AT with serial1.println but the wifi not respond.
I place the oscilloscope on RX and i have not of respond.
Furthermore, i measure a voltage of 3.5V...? (not 5V?).
Do i put a resistor of pull-up?
Thank in advance,
Best regards
2016-07-08 23:02:50 Aho, got it, so you sent the AT commands originally for ESP to this wifi shield...seems you are browsing many wifi modules.
Just a interesting question Id like to know, which module do you love the most? ;)
userHeadPic Leff
2016-07-08 12:18:30 Yes, of course !
I sent the commands of ESP and not of wifi shield...
I come to test your commands of wifi shield and it work !
Again thank. :D
userHeadPic peetscholsem
2016-07-08 02:07:41 I thought you are using this wifi shield, https://www.dfrobot.com/wiki/index.php?t ... KU:TEL0078, isn't it? :shock: userHeadPic Leff
2016-07-08 00:50:34 Thank you very much.
I try this evening.
I don't watch correctly.
I have used an esp8266 and i had to send the commands AT...
It's strange to send "+++" but it's write in the datasheet !
2016-07-07 23:56:11 Hi,
I found nothing talking about how to use AT command in the wiki. However, I found some notes in its user manual, here is the manual download link https://github.com/Arduinolibrary/DFRob ... 20V2.4.pdf
And at page 53 and 54, it reads this:
So I tried on UNO through Serial monitor, no problem as you could see
Also I wrote a simple code for Leonardo, after uploading, OPEN the Serial monitor, I could see I successfully entered AT mode and received responce.
the code:
Code: Select all
void setup() {
  Serial.begin(115200);
  Serial1.begin(115200);
  while (!Serial) {
  Serial.println("Prepare to enter AT mode.");
  Serial1.print("+++");
  delay(50);
  Serial1.print("a");
  delay(100);
  while (Serial1.available()) {
    char inData = Serial1.read();
    if ( inData == 'k') {
      Serial.println("+ok");
      Serial.println("Entered AT mode.");
      break;
void loop() {
  Serial1.println("AT+WMODE");
    Serial.write(Serial1.read());
  delay(1000);
userHeadPic Leff
2016-07-07 11:02:31 There is news.
The connection with USB key receive the datas if i configure the wifi shield with the web page (10.10.100.254). I connect me with my smartphone on the server of wifi shield. And i receive the datas in "Docklight". On the other side, the command AT always don't work ?!
2016-07-07 09:26:19 Hi Leff
A : I have not an uno but i have an arduino mini.
B : I have not to try with LF then CR. I can to try with "Serial.print("AT\n\r");" or "Serial.write("("AT\n\r");".
I have also to connect the wifi shield on the PC with a USB key and the UART connector. I can send any commands with "docklight".
Little precision, the Leds Power and Ready are lit.
What do you want as picture ?
2016-07-07 02:52:09 Hi peetscholsem,
Just pass-by and saw your post... you may check:
  1. can it be used on Uno, instead of Leonardo?
  2. <CR+LF>, i.e. \r\n, means Carriage-Return and Line-Feed, which is the same meaning with "Both NL & CR" in Arduino Serial monitor, do not include the string "<CR+LF>" itself.
could you post some pictures?
Maybe tomorrow I can test this module with Leonardo.
userHeadPic Leff
2016-07-07 02:00:25 I connect the shield with USB on the PC and i receive nothing ! (I send "AT\r\n" or "AT\r" but not of reception)
The connections RX and TX is weld correctly. (check with multimeter)
