ICE Tower Cooler for Raspberry Pi 5 Single Board Computer
$17.90
SKU: FIT0978
  • $17.50 3+ items
  • $17.00 5+ items
  • $16.50 10+ items
RGB cooling fan for Raspberry Pi 5, featuring a tower design with adjustable-speed fan and automatic RGB lights. Efficient, easy to install, and prevents overheating.
This ice tower-style RGB cooling fan is designed for Raspberry Pi 5, consisting of a high tower-type heat-sink with multiple aluminum fins, two metal brackets, an acrylic baseplate, and an adjustable-speed fan.
Its tower design provides maximum surface area, enhancing cooling performance. The included fan is located at the top of the tower, directing air directly onto the heat-sink, helping to accelerate the cooling process by increasing airflow over the fins. The cooling fan can automatically adjust its speed based on the temperature of the Raspberry Pi 5. Additionally, the cooling fan features RGB lights that change colors automatically, creating a dazzling display when the fan operates at high speed!
The Raspberry Pi 5 ice tower-style RGB cooling fan is an effective cooling solution, helping to maintain optimal operating temperatures for the Raspberry Pi 5 and ensuring reliable performance for various applications and use cases.
Dimensions of ICE Tower Cooler for Raspberry Pi 5 Single Board Computer
Installation Steps for the ICE Tower Cooler and Raspberry Pi 5 Single Board Computer
  • Efficient Cooling
  • Tower Design
  • High-Quality Fan
  • Easy Installation
  • Prevents Overheating
  • Extends Lifespan
  • Versatile Applications
  • Durable Construction
  • Compact and Space-Saving
  • Compatibility: Raspberry Pi 5 4GB / 8GB
  • Dimensions: 42.5 x 40 x 35 mm
  • Weight: 120 g
  • Ice Tower cooler with Fan ×1
  • Metal Brackets for Ice Tower cooler ×2
  • Acrylic bottom panel ×1
  • Screw driver ×1
  • M2.5 ball head screw ×6
  • Hand-tightened copper nut ×4
  • Copper pillar ×8
  • Thermal pad for Raspberry Pi 5 ×4
  • ICE Tower Cooler for Raspberry Pi 5 Single Board Computer
