Huskylens AI Vision Sensor can be used in the FIRST Tech Challenge Game. In this article, we will show how to use Huskylens AI Camera to identify April Tag. Tag Recognition function can detect tags, and learn, recognize, track specified tags. These tags are called April Tags.
Click here to download more April Tags.
Tips: Only April Tags can be regonized.
The default setting is to learn a single tag. This chapter uses learning, recognizing, and tracking multiple tags as an example to demonstrate.
You can use the following tags to test this function.
1. Tag Detection: When Huskylens detects the tag, the tag will be automatically selected by the white frame on the screen.
2. Tag Learning: Point the “+” symbol at the first tag, and press the “learning button”. A yellow frame with words "Tag:ID1" will be displayed on the screen, indicating that HuskyLens is learning the tag now. Then, release the "learning button" to complete learning the first tag, meanwhile, a message "Click again to continue! Click other button to finish" will be displayed. Please short press the "learning button" before the countdown ends if you want to learn other tags. If not, short press the "function button" before the countdown ends, or do not press any button to let the countdown ends.
3. Tag Recognition: When encountering the learned tag, some color frames with IDs will be automatically displayed on the screen. The size of the frames changes with the size of the tags, and the frames automatically track these tags.
Gravity: HUSKYLENS with Silicone Case
SKU: SEN0305-S
