The adoption of RISC-V, a free and open-source computer instruction set architecture first introduced in 2010, is rapidly accelerating, driven primarily by the increasing demand for AI and Machine Learning(ML). Research firm Semico projects a staggering 73.6 percent annual growth in the number of chips incorporating RISC-V technology, with a forecast of 25 billion AI chips by 2027 generating a revenue of US $291 billion. This article will highlight the popular RISC-V Architecture-based chip products for AI and ML currently accessible in the market.
The Intelligence X390 processor is designed to meet the increasing demands of artificial intelligence and machine learning applications. It builds upon the foundation of the X280 with key enhancements that significantly boost its computational capabilities. Featuring a single-core configuration, the processor provides a fourfold improvement in vector computation through dual vector ALU setup and doubled vector length, resulting in a quadruple increase in sustained data bandwidth. Additionally, the processor integrates SiFive's VCIX technology, allowing companies to incorporate custom vector instructions or acceleration hardware for unprecedented performance optimization flexibility. The enhanced vector computation capabilities make the X390 processor particularly suitable for neural network training and inference tasks.
SiFive has released new processors to target machine learning and general-purpose HPC
SiFive Performance P870 is a processor core based on the RISC-V architecture and is part of the SiFive Performance series. Designed for high-performance computing and data center applications, the SiFive Performance P870 processor core boasts robust processing capabilities and flexible customization. Leveraging the open instruction set architecture of RISC-V, this processor core can meet the demands of various complex computing tasks, including artificial intelligence, big data analytics, and high-performance computing. The SiFive Performance P870 aims to provide customers with high-performance, low-power processor solutions to meet the growing demands of computation.
These two processors differ in design objectives and application focus. The SiFive Performance P870 is primarily used for high-performance computing and data center applications, while the SiFive Intelligence™ X390 is designed for edge artificial intelligence and machine learning applications.
T-Head XuanTie C910 delivers industry-leading performance in control flow, computing and frequency through architecture and micro-architecture innovations. The C910 processor is based on the RV64GC instruction set and implements the XIE (XuanTieInstruction Extension) technology. C910 adopts a state-of-the-art 12-stage out-of-order multiple-issue superscalar pipeline with high frequency, iPC, and power efficiency. C910 supports hardware cache coherency. Each cluster contains 1-4 cores. The C910 supports the AXI4bus interface and includes a device coherence port. The C910 uses the SV39 virtual address system with XMAE (XuanTie Memory AttributesExtension) technology. In addition, C910 includes the standard CLINT and interrupt controllers and supports RV-compatible debug interface and performance monitors.
The C908 64-bit RISC-V core adopts the RV64GCB[V] instruction and complies with the RVA22 profile for better compatibility with Android and other “rich” operating systems. Its performance is between the C906 and C910 cores introduced in 2020 and 2019 respectively.
In May 2023, the Chinese Academy of Sciences released the second generation "Xiangshan" (Nanhu architecture) open-source high-performance RISC-V processor core, which was completed in September 2022 and taped out in June 2023. This processor core adopts the 14nm process of SMIC, with a main frequency of 2 GHz, a SPEC CPU score of 10/GHz, dual-channel DDR memory, dual-channel PCIe interface, USB interface, HDMI interface, and more. Its comprehensive strength surpasses that of ARM's Cortex-A76, making it the world's most powerful RISC-V core.
The Esperanto ET-SoC-1 chip integrates over 1000 RISC-V processor cores and 24 billion transistors, including 1088 energy-efficient ET-Minion 64-bit RISC-V in-order cores and 4 high-performance ET-Maxion 64-bit RISC-V out-of-order cores. Each core is equipped with a vector/tensor unit, with expected operating frequencies ranging from 500MHz to 2GHz. Additionally, the chip incorporates 1 RISC-V service processor, over 160 million bytes of on-die SRAM for caches and scratchpad memory, and interfaces supporting large external memory, including LPDDR4x DRAM and eMMC flash, PCIe x8 Gen4, and other common I/O interfaces. At peak rates, the ET-SoC-1 is capable of achieving 100 to 200 Tera Operations per Second (TOPS), while typically consuming less than 20 watts of power. What sets Esperanto’s solution apart is how each board uses multiple low-power SoC chips instead of a giant SoC. It could be used as a compelling energy-efficient solution for Machine Learning recommendation in large data centers.
MTIA is designed by Meta to handle their AI workloads more efficiently. The processor cores are based on the RISC-V open instruction set architecture (ISA). The chip is a custom Application-Specific Integrated Circuit (ASIC) built to improve the efficiency of Meta's recommendation systems, e.g. Content understanding, Facebook Feeds, generative AI, and ads ranking all rely on deep learning recommendation models (DLRMs), and these models demand high memory and computational resources.
The first-generation MTIA ASIC was designed in 2020 specifically for Meta's internal workloads. The chip was fabricated using the TSMC 7nmœ process and runs at 800 MHz, providing 102.4 TOPS at INT8 precision and 51.2 TFLOPS at 16-bit floating-point precision. It also features a thermal design power (TDP) of 25 W. The MTIA chip is part of a full-stack solution that includes silicon, PyTorch, and recommendation models; all co-designed to offer a wholly optimized ranking system for Meta’s customers. The release of their first AI chip, MTIA, is a significant development. It further fuels the AI hardware race and contributes to the evolution of hardware designed specifically for AI applications.
The chips listed in the article feature a multi-core design, with each core offering high performance and energy efficiency. They support multi-threaded operations, enabling simultaneous execution of multiple tasks. Additionally, they all support Single Instruction Multiple Data (SIMD) instruction sets, which can accelerate parallel data processing tasks such as image processing and vector calculations. As the industry progresses, we believe that chip products based on the RISC-V architecture will play an increasingly vital role in AI and ML applications, providing a solid foundation for future technological innovations and applications.
