#include "SoftwareSerial.h" #include "DFRobotDFPlayerMini.h" //Inicia a serial por software nos pinos 10 e 11 SoftwareSerial mySoftwareSerial(10, 11); // RX, TX DFRobotDFPlayerMini myDFPlayer; char command; int pausa = 0; void setup() { //Comunicacao serial com o modulo mySoftwareSerial.begin(9600); //Inicializa a serial do Arduino Serial.begin(115200); //Verifica se o modulo esta respondendo e se o //cartao SD foi encontrado Serial.println(); Serial.println(F("DFRobot DFPlayer Mini")); Serial.println(F("Initializing DFPlayer module ... Wait!")); if (!myDFPlayer.begin(mySoftwareSerial)) { Serial.println(F("Not initialized:")); Serial.println(F("1. Check the DFPlayer Mini connections")); Serial.println(F("2. Insert an SD card")); while (true); } Serial.println(); Serial.println(F("DFPlayer Mini module initialized!")); //Definicoes iniciais myDFPlayer.setTimeOut(500); //Timeout serial 500ms myDFPlayer.volume(5); //Volume 5 myDFPlayer.EQ(0); //Equalizacao normal menu_opcoes(); } void loop() { //Waits for data entry via serial while (Serial.available() > 0) { command = Serial.read(); if ((command >= '1') && (command <= '9')) { Serial.print("Music reproduction"); Serial.println(command); command = command - 48; myDFPlayer.play(command); menu_opcoes(); } //Reproduction //Stop if (command == 's') { myDFPlayer.stop(); Serial.println("Music Stopped!"); menu_opcoes(); } //Pausa/Continua a musica if (command == 'p') { pausa = !pausa; if (pausa == 0) { Serial.println("Continue..."); myDFPlayer.start(); } if (pausa == 1) { Serial.println("Music Paused!"); myDFPlayer.pause(); } menu_opcoes(); } //Increases volume if (command == '+') { myDFPlayer.volumeUp(); Serial.print("Current volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } if (command == '<') { myDFPlayer.previous(); Serial.println("Previous:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()-1); menu_opcoes(); } if (command == '>') { myDFPlayer.next(); Serial.println("next:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()+1); menu_opcoes(); } //Decreases volume if (command == '-') { myDFPlayer.volumeDown(); Serial.print("Current Volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } } } void menu_opcoes() { Serial.println(); Serial.println(F("==================================================================================================================================")); Serial.println(F("Commands:")); Serial.println(F(" [1-3] To select the MP3 file")); Serial.println(F(" [s] stopping reproduction")); Serial.println(F(" [p] pause/continue music")); Serial.println(F(" [+ or -] increases or decreases the volume")); Serial.println(F(" [< or >] forwards or backwards the track")); Serial.println(); Serial.println(F("=================================================================================================================================")); }
void loop() { //Waits for data entry via serial while (Serial.available() > 0) { command = Serial.read(); if ((command >= '1') && (command <= '3')) { Serial.print("Music reproduction"); Serial.println(command); command = command - 48; myDFPlayer.play(command); menu_opcoes(); } //Reproduction //Stop if (command == 's') { myDFPlayer.stop(); Serial.println("Music Stopped!"); menu_opcoes(); } //Pausa/Continua a musica if (command == 'p') { pausa = !pausa; if (pausa == 0) { Serial.println("Continue..."); myDFPlayer.start(); } if (pausa == 1) { Serial.println("Music Paused!"); myDFPlayer.pause(); } menu_opcoes(); } //Increases volume if (command == '+') { myDFPlayer.volumeUp(); Serial.print("Current volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } if (command == '<') { myDFPlayer.previous(); Serial.println("Previous:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()-1); menu_opcoes(); } if (command == '>') { myDFPlayer.next(); Serial.println("next:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()+1); menu_opcoes(); } //Decreases volume if (command == '-') { myDFPlayer.volumeDown(); Serial.print("Current Volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } } }The user can send the following control characters:
if ((command >= '1') && (command <= '3')) { Serial.print("Music reproduction"); Serial.println(command); command = command - 48; myDFPlayer.play(command); menu_opcoes(); } //Reproduction //Stop if (command == 's') { myDFPlayer.stop(); Serial.println("Music Stopped!"); menu_opcoes(); } //Pausa/Continua a musica if (command == 'p') { pausa = !pausa; if (pausa == 0) { Serial.println("Continue..."); myDFPlayer.start(); } if (pausa == 1) { Serial.println("Music Paused!"); myDFPlayer.pause(); } menu_opcoes(); } //Increases volume if (command == '+') { myDFPlayer.volumeUp(); Serial.print("Current volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } if (command == '<') { myDFPlayer.previous(); Serial.println("Previous:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()-1); menu_opcoes(); } if (command == '>') { myDFPlayer.next(); Serial.println("next:"); Serial.print("Current track:"); Serial.println(myDFPlayer.readCurrentFileNumber()+1); menu_opcoes(); } //Decreases volume if (command == '-') { myDFPlayer.volumeDown(); Serial.print("Current Volume:"); Serial.println(myDFPlayer.readVolume()); menu_opcoes(); } }So, if you applied all the steps presented, you were able to learn:
