SELECTION GUIDE GravityArduino
Gravity CO2 Sensor Selection Guide
DFRobot Mar 25 2020 261293
Imagine a world where you can effortlessly monitor and control the air quality in your home, office, or even your greenhouse. Welcome to our 'Gravity CO2 Sensor Selection Guide', your gateway to this reality. We're excited to introduce you to four cutting-edge Gravity CO2 sensors, each with its unique strengths and applications.
This article, the "CO2 Sensor Selection Guide," showcases four distinct Gravity CO2 sensor options for your consideration: the "Analog Electrochemical Carbon Dioxide Sensor," "PWM Infrared Carbon Dioxide Sensor," "UART Infrared Carbon Dioxide Sensor," and "I2C SCD41 Infrared CO2 Sensor." Each sensor possesses unique operation principles, measurement ranges, accuracies, and applicable scenarios to cater to various needs and budgets.
Whether you're a DIY enthusiast working on your next big project, a scientist striving for accuracy in the lab, a farmer seeking to optimize your greenhouse conditions, or a homeowner looking to enhance the quality of your indoor environment, we've got you covered. Dive into our guide and find the CO2 sensor that will transform your world. Happy exploring!
Product Name
Gravity: Analog Electrochemical Carbon Dioxide Sensor (0-10000 ppm)
Gravity: PWM Infrared Carbon Dioxide Sensor (400-5000 ppm)
Gravity: UART Infrared Carbon Dioxide Sensor (0-50000 ppm)
Gravity: I2C SCD41 Infrared CO2 Sensor (400 - 5000 ppm)
Figure
SKU
SEN0159
SEN0219
SEN0220
SEN0536
IC/Module
MG-811
MH-Z14
MH-Z16
SCD41
Operation Voltage
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: Analog(Analog2.7~4.1V)+3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART(0~3.3V Level)
Gravity: I2C
Measurement Principle
Electrochemistry(Solid electrolyte battery principle)
NDIR(non-dispersive infrared)
photoacoustic NDIR
Measurement Range
0~10000 ppm
0~5000 ppm
0~50000 ppm
400 - 5000 ppm
Accuracy
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<90s
<30s
60s
Average Power
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
0~95% RH (No condensation)
Lifespan
>1 years
>5 years
>5 years
>10 years
Dimension (PCB)
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. Expansive measurement range 2. Vast temperature range 3. Customizable alarm threshold 4. Swift and responsive 5. Analog output capability
1. High accuracy 2. Prolonged lifespan 3. Automatic temperature compensation 4. Resistant to water vapor interference 5. Analog output capability
1. High accuracy 2. Wide-ranging capability 3. Extended operational lifespan 4. Automatic temperature compensation 5. Resilient against water vapor interference 6. 3.3V serial port output
1. Tripartite integration of CO2, temperature, and humidity 2. Compact dimensions of 32*27*8mm 3. Low power consumption, with an average current of less than 4mA 4. Remarkably long operational lifespan
Suggested Application Scenarios
As a CO2 sensor with a wide temperature range and affordable price, this sensor exhibits low power consumption, fast response speed, and the ability for long-term online monitoring. It is suitable for low-cost applications where high precision is not required, such as monitoring CO2 levels in small indoor rooms or DIY projects.
As a high-precision CO2 sensor, it is well-suited for applications that require accurate measurements of CO2 concentration in environments where the concentration levels are not excessively high. Examples of such environments include smart homes, classrooms, or offices where indoor air quality monitoring is of utmost importance.
As a high-precision and wide-ranging CO2 sensor, it is suitable for applications that require measuring high concentrations of CO2 with exceptional accuracy. Examples of such environments include chemical laboratories, agricultural greenhouses, and monitoring production processes in industrial settings.
This sensor with its "tripartite integration" functionality and long operational lifespan is well-suited for applications that require simultaneous measurement of CO2, temperature, and humidity. Examples of such application scenarios include indoor air quality monitoring, greenhouse detection, smart homes, and control of air conditioning systems.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
