SELECTION GUIDE DFRobotEnglish
Microcontroller (Small Size) Selection Guide
DFRobot Jul 29 2020 260219
Microcontroller(Small Size) Selection Guide
Product Name
Beetle
DFRduino Pro Mini V1.3 16M5V328
DFRduino Pro Mini V1.3 - 8M3.3V328 (Discontinued)
Dreamer Nano V4.1
DFRduino Nano
Bluno Nano
Figure
SKU
DFR0282
DFR0159
DFR0132
DFR0213
DFR0010
DFR0296
Processor
ATmega32u4
ATmega328
ATmega328
ATmega32u4
ATmega328
ATmega328
Board Type
Arduino Leonardo
Arduino Pro Mini(16M)
Arduino Pro Mini(8M)
Arduino Leonardo
Arduino Nano/ATmega328
Arduino UNO
Operating Voltage (voltage / input voltage)
5 V/3-5 V
5 V/3.6-8 V
3.3 V/3.6-8 V
5 V/7-12 V
5 V/7-12 V
5 V/7-12 V
CPU Frequency
16MHz
16MHz
8MHz
16MHz
16MHz
16MHz
Flash[KB]
32
32
32
32
32
32
Analog Ports (Input / output)
5 / 0
8 / 0
8 / 0
12 / 0
8 / 0
6 / 0
Digital Ports (IO/PWM)
10 / 4
14 / 6
14 / 6
20 / 7
14 / 6
14 / 6
UART
1
1
1
2
1
1
I2C
1
1
1
1
1
1
Download
Micro USB
FTDI Downloader
FTDI Downloader
Micro USB
Mini USB
Micro USB
Dimension
20 x 22mm
33 x 18mm
33 x 18mm
45 x 20mm
47 x 19mm
53 x 19mm
*The beetle is one of the smallest Arduino Leonardo board. *It is compatible with Micro USB so that direct programming and testing is no longer a headache. *Suitable for artists and designers to make small and delicate Arduino works.
*DFRduino Pro Mini is small but powerful. It has a strong chip. *It performs well even compared with Arduino boards of standard size. *It can be widely applied to flight controllers, small machines. And it can satisfy people's special requirements for size.
*The only difference between the DFRduino Pro Mini V1.3(8M3.3V328) and Pro Mini V1.3 (16M5V328) is that the later has an operating voltage of 3.3V. *Both of them have 2 analogs I/O than normal main controllers.
*The ATmega32u4 chip used by the DFRduino Nano. It looks like the Nano, but the function is more powerful. *It is the most IO port and UART master controller in microcontrollers. *It can be widely applied to dual-string communication systems.
*DFRduino Nano adopts ATmega328, which is totally compatible with Arduino Nano. *It is suitable for all scenarios that need to be compatible with Arduino UNO or DFRduino UNO.
*Bluno Nano is a mini Arduino master with Bluetooth 4.0. *It brings more possibilities and freedom to the development of Android and IOS mobile applications. *It is suitable for Bluetooth developers with special size requirements.
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
