When it comes to a moment on choosing IoT devices, we are curious about what matters the most?
According to the feedback from technicians, most of them mentioned that ease of development, data acquisition, processing and storage requirements, and physical device design are the most common factors to consider. While we detect that two requirements of IoT device are prior to all the others - power consumption and fairly low cost.
The devices we are going to showcase is low-power-consumption IoT products with high performance in the mainstream. Hereby we hold a IoT Product Day Sales during every 5th-7th(GMT +8).
DFRobot FireBeetle series are low power consumption microcontrollers designed for Internet of Things (IoT) development. This Bluetooth controller combines Bluetooth Low Energy 4.1 with Arduino controller, offering functions similar to the former Bluno series but with lower power consumption.
Firebeetle ESP8266 is a development board integrated with IoT WiFi, TCP/IP, 32-bit MCU, 10-bit ADC and multiple interfaces such as HSPI, UART, PWM, I2C and I2S. In DTIM10, the full power consumption to maintain WiFi connection reached to 1.2mW. Equipped with 16MB outer SPI flash memory, ESP8266 is available for programs and firmware storage.
Compatible with Arduino programming enables Firebeetle ESP8266 to lower the barrier of programming. Operator can implement Arduino programming codes directly onto ESP8266 to reduce the difficulty of operating and increase the stability of board.
Bluno Bee is a serial to bluetooth 4.0 module, it adopts XBEE form factor which is compact and is compatible with all shields with XBEE socket. Bluno Bee is designed to have voltage regulator which supports both 5V and 3.3V MCUs. Bluno Bee is talking to your Arduino serial port , and able to turn your arduino to bluetooth 4.0 (BLE) ready instantly.
Think about a new type of LED and a new way of interactive controlling for different scenes! With just a mobile device that has Bluetooth4.0 (BLE), you can easily control every single LED in the lace, program the LEDs individually and react to beautiful rhythms anytime. Whats more, the kit can be divided conveniently into separate parts, so you can make more use in your Arduino project wherever you want to.
The upgraded Arduino Input Shield includes a two axis mini joystick (with moment switch) as well as four colored push buttons(Red,Yellow,Blue,Green). The reserved APC220 Radio Data Module(SKU:TEL0005) interface and the Xbee interface is deisgned to facilitate the realization of wireless rocker button controller. The shield can be easily stacked on top of your Arduino boards. It can also connect with OLED2864 & OLED9664.
Avoid upcoming China tariffs! DFRobot's new California warehouse offers popular development boards, sensors, and kits with tariff-free US shipping. Shop now and save!
DFRobot is heading to Embedded World 2025 in Nuremberg, Germany, from March 11-13, and we’re bringing the latest in embedded computing, IoT, and industrial solutions.
This article introduces the Mind+(Mindplus) editor, which seamlessly combines block-based and text coding in its interface, facilitating an easier transition.
