Forum >Error when compiling for ESP32
Hi there
I encountered this error when doing a simple wifi scan.
WARNING: library SPI claims to run on (esp32) architecture(s) and may be incompatible with your current board which runs on (DFRobot_FireBeetle-ESP32) architecture(s).
it's the example code for the FireBettle ESP32 and it failed. I tried with multiple firebettle Esp32 board and all failed. can you provide some assistance/
Thank you
Thank you
