Forum >SIM7000E Shield: BME280 works, SIM7000E does not
userHead Account cancelled 2018-06-29 08:34:57 5910 Views8 Replies
I can talk to the BME280, but the SIM7000E doesn't seem to init. Must I have a SIM card inserted? If so, do I need a special LTE-M SIM card?
Thanks!
2020-01-13 19:40:41 Yes, the switch is connected as TX 8 , RX 7.
What could be the reason that SIM7000 is not turning on.
userHeadPic ssz_shah50
2020-01-08 20:51:23 Hi there,
The code is definitely updated now but instead of errors my serial monitors say Turning on SIM7000...
and that's it!
it doesn't go anywhere ahead of this message.But with the BME sensor code that works totally fine.
Can you please guide me what might be the problem.
Regards
2020-01-01 21:10:49 Im having the same problem. It looks like the library has been updated but the DFRobot wiki example has not. Pretty poor effort at support and nobody answered your question. userHeadPic sjowett63
2019-02-16 09:48:33 I was trying to test the SIM7000E Arduino NB-IoT/LTE/GPRS/GPS Expansion Shield GPRS shield with the demo code that DFR has given in there wiki page…I installed the said library(file:///C:/Users/Kishor/Downloads/DFRobot_SIM7000-master.zip). But many errors while trying to compile for Arduino Uno. I even had to install DFRobot_SIM Library …Still following errors!
Please help...
I am here by copying the error codes…(Sorry just copied from Arduino IDE)
Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\kumark\Desktop\SIM700E_test\SIM700E_test.ino: In function ‘void setup()’:
SIM700E_test:36: error: ‘class DFRobot_SIM7000’ has no member named ‘setNet’
if(sim7000.setNet(NB)){ //Set net mod NB-IOT
SIM700E_test:56: error: ‘class DFRobot_SIM7000’ has no member named ‘connect’
if(sim7000.connect(TCP,“www.taobao.com”,80)){ //Start Up TCP or UDP Connection
SIM700E_test:68: error: ‘class DFRobot_SIM7000’ has no member named ‘close’
if(sim7000.close()){ //End the connection
Multiple libraries were found for “SoftwareSerial.h”
Used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Not used: \JacobOram\user1\kumark\Documents\Arduino\libraries\SoftwareSerial
Multiple libraries were found for “Wire.h”
Used: \JacobOram\user1\kumark\Documents\Arduino\libraries\Wire
Not used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
exit status 1
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
userHeadPic drkishorkks
2018-06-29 22:54:31 Hi,
SIM7000E supports the Quad-Band FDD-LTE B3/B8/B20/B28,GPRS/EDGE 900/1800 MHz, the band mostly available in Europe.
userHeadPic robert.chen
