Forum >Re: MEGA logger sketch updated
Telematics General
userHead mattt 2013-10-06 10:34:43 4444 Views3 Replies
Hi, thanks for the update. I am getting an issue where it keeps reconnecting once it connects to OBD, like it is stuck in a loop, while creating and closing the data files.
2013-10-18 14:02:52 I get the following error when building in Codeblocks:
megalogger.ino: In member function 'virtual void COBDLogger::dataIdleLoop()':
megalogger.ino:297: error: 'getState' was not declared in this scope
megalogger.ino:297: error: 'OBD_CONNECTED' was not declared in this scope
opening megalogger.cbp in:
[url=http://sourceforge.net/projects/obdcon/files/logger/megalogger-src-20131005.zip/download]http://sourceforge.net/projects/obdcon/files/logger/megalogger-src-20131005.zip/download[/url]
I bought kit #3 and is starting out fresh, so i might need a bit more help than the regulars please.
Kind regards,
/Stefan
userHeadPic Sone
2013-10-07 11:28:06 I changed the class back to COBD and am getting the same thing as Matt.  It seems to be more reliable about the connections, but the logic that is forcing the reconnect (error count) seems to be goofed up.
I get one good read of the tachometer pid and it resets.
Sb.
ps.  I pulled the code 30 minutes ago.
userHeadPic sbirdranch
2013-10-07 10:50:13 Stanley,
  I just pulled the code from GitHub and you have again pushed a change that has the COBDI2C library reference.
Sb.
