Forum >How to open the adapter-Solved
When I plugged the adapter into the OBD port, the pins were pushed into the adapter. Pin layout is correct so it looks like the tabs on the pins were not fully engaged. No power was put to the adpater so there was no risk of a short. Crap happens but I am confident that this is an easy fix. I want to open the case and fix the pins. I will be taking pictures for an "instructable" so I would prefer not to scratch the case up.
I am testing each item out step by step. So far the arduino and the OLED work great. Also managed to get it to work with a 20x4 display as well. Next will be the SD and then logging. I just have to fix the pins so that I can continue.
Thank you!
Paul
Thank you!
Paul
2013-12-03 19:49:22 Thank you Stanley,
I have a solid 5v now. Time to wire wire everything up and go for a test run.
Thank you very much for your help.
Paul
PaulH
Paul
