Forum >Freemantics OBD II Adaptor - Startup
Telematics General
userHead MrIon 2013-11-27 14:53:20 13969 Views19 Replies
I got the fremantics OBD II Adaptor. I want to program it using an USBASP, so I got one and connected it according to the link below: [url=http://arduinodev.com/programming-freematics-obd-ii-adapter/]http://arduinodev.com/programming-freematics-obd-ii-adapter/[/url]
I then downloaded the required libraries and the Arduino software. I changed under Tools/Board to Microduino- Core+ ([email protected],5v) on COM 1. Also have the programmer as USBasp. I tried to get the computer to recognize it, but it doesn't seem to find it at all. Am I missing a step?
I then opened up rpm_led example and hit verify and I get nothing but errors. I included a screen shot of the errors.
2013-12-17 19:36:12 Where's the SD pin on the freematics? Is it the SS or 10? userHeadPic MrIon
2013-12-17 16:12:37 Nevermind. I forgot to add the OBD.cpp and OBD.h files in my Codeblock sources. userHeadPic MrIon
2013-12-17 15:52:56 I get this error now:
userHeadPic MrIon
userHeadPic MrIon
2013-12-16 09:35:06 the datalogger is already on the m644p right? I suggest disabling LCD display by uncommenting the line in config.h:
[code]LCD_Null lcd;[/code]
and comment out:
[code]LCD_SSD1306 lcd;[/code]
userHeadPic MrIon
and comment out:
userHeadPic MrIon
2013-12-15 11:54:13 I made an app that connected to the ble frematics in Android. Now how do I grab information from the bluetooth in order to get lets say the engine RPM? userHeadPic MrIon
2013-12-12 19:38:11 Nevermind I figured it out. I had spaces in the my folder structures and it didn't like that( for example OBD Project) as soon as I named it OBDProject and resaved it worked. userHeadPic MrIon
2013-12-12 19:19:20 So I've been playing around and I got the OBD.cpp and OBD.h in a Ardunio project under the CodeBlocks program. Everything build with no problem. Now I'm trying to use the USBtiny programmer however I get an error. Here's what the debug window says:
Scanning for lexers in C:\Users\Marius\Desktop\CodeBlocks/share/codeblocks/lexers/...
Found 45 lexers
Found 45 lexers
Loading lexer_A68k
Loading lexer_ada
Loading lexer_angelscript
Loading lexer_bash
Loading lexer_batch
Loading lexer_bibtex
Loading lexer_caml
Loading lexer_cg
Loading lexer_cmake
Loading lexer_cpp
Loading lexer_css
Loading lexer_d
Loading lexer_diff
Loading lexer_f77
Loading lexer_fortran
Loading lexer_glsl
Loading lexer_gm
Loading lexer_haskell
Loading lexer_hitasm
Loading lexer_html
Loading lexer_java
Loading lexer_latex
Loading lexer_lisp
Loading lexer_lua
Loading lexer_make
Loading lexer_masm
Loading lexer_matlab
Loading lexer_nsis
Loading lexer_OgreCompositor
Loading lexer_OgreMaterial
Loading lexer_pascal
Loading lexer_perl
Loading lexer_postscript
Loading lexer_prg
Loading lexer_properties
Loading lexer_python
Loading lexer_rc
Loading lexer_ruby
Loading lexer_smalltalk
Loading lexer_sql
Loading lexer_squirrel
Loading lexer_vbscript
Loading lexer_verilog
Loading lexer_vhdl
Loading lexer_xml
Loading lexer_A68k
Loading lexer_ada
Loading lexer_bash
Loading lexer_batch
Loading lexer_caml
Loading lexer_cg
Loading lexer_cmake
Loading lexer_cpp
Loading lexer_css
Loading lexer_d
Loading lexer_diff
Loading lexer_f77
Loading lexer_glsl
Loading lexer_gm
Loading lexer_html
Loading lexer_java
Loading lexer_latex
Loading lexer_lisp
Loading lexer_lua
Loading lexer_make
Loading lexer_masm
Loading lexer_nsis
Loading lexer_perl
Loading lexer_prg
Loading lexer_rc
Loading lexer_ruby
Loading lexer_sql
Loading lexer_vhdl
Loading lexer_xml
Configured 7 tools
Scanning for plugins in C:\Users\Marius\Desktop\CodeBlocks/share/codeblocks/plugins
Loaded 17 plugins
Loaded 17 plugins
Loading:
Abbreviations
AStylePlugin
Autosave
ClassWizard
CodeCompletion
Compiler
CppCheck
Debugger
FilesExtensionHandler
HexEditor
OpenFilesList
ProjectsImporter
ScriptedWizard
SmartIndentCpp
SmartIndentXML
ToDoList
WindowsXPLookNFeel
Running startup script
Script plugin registered: Find Broken Files plugin
Script/function 'edit_startup_script.script' registered under menu '&Settings/-Edit startup script'
Create new parser for project 'OBDtest1'
Project 'OBDtest1' parsing stage done!
Deleting parser for project 'OBDtest1'!
Launching tool 'Upload via USBtiny': C:\Users\Marius\Desktop\CodeBlocks/cb_console_runner.exe bin/avrdude -e -F -C bin/avrdude.conf -V -patmega644p -cusbtiny -Pusb -Uflash:w:C:\Users\Marius\Desktop\OBD Project\OBD Prototype\OBDtest1\/build\OBDtest1_uduino644p.elf.hex:i  -Ueeprom:w:C:\Users\Marius\Desktop\OBD Project\OBD Prototype\OBDtest1\build\OBDtest1_uduino644p.elf.eep.hex:i (in C:\Users\Marius\Desktop\CodeBlocks\bin)
Tool execution terminated with status 1
userHeadPic MrIon
Found 45 lexers
Found 45 lexers
Loading lexer_A68k
Loading lexer_ada
Loading lexer_bash
Loading lexer_batch
Loading lexer_caml
Loading lexer_cg
Loading lexer_cmake
Loading lexer_cpp
Loading lexer_css
Loading lexer_d
Loading lexer_diff
Loading lexer_f77
Loading lexer_glsl
Loading lexer_gm
Loading lexer_html
Loading lexer_java
Loading lexer_latex
Loading lexer_lisp
Loading lexer_lua
Loading lexer_make
Loading lexer_masm
Loading lexer_nsis
Loading lexer_perl
Loading lexer_prg
Loading lexer_rc
Loading lexer_ruby
Loading lexer_sql
Loading lexer_vhdl
Loading lexer_xml
Loading lexer_A68k
Loading lexer_ada
Loading lexer_bash
Loading lexer_batch
Loading lexer_caml
Loading lexer_cg
Loading lexer_cmake
Loading lexer_cpp
Loading lexer_css
Loading lexer_d
Loading lexer_diff
Loading lexer_f77
Loading lexer_glsl
Loading lexer_gm
Loading lexer_html
Loading lexer_java
Loading lexer_latex
Loading lexer_lisp
Loading lexer_lua
Loading lexer_make
Loading lexer_masm
Loading lexer_nsis
Loading lexer_perl
Loading lexer_prg
Loading lexer_rc
Loading lexer_ruby
Loading lexer_sql
Loading lexer_vhdl
Loading lexer_xml
Configured 7 tools
Loaded 17 plugins
Loaded 17 plugins
Loading:
Abbreviations
AStylePlugin
Autosave
ClassWizard
CodeCompletion
Compiler
CppCheck
Debugger
HexEditor
OpenFilesList
ProjectsImporter
ScriptedWizard
SmartIndentCpp
SmartIndentXML
ToDoList
WindowsXPLookNFeel
userHeadPic MrIon
2013-12-07 14:46:53 I found a USBtiny device that worked. Now what do I do in order to start programming on it? userHeadPic MrIon
2013-11-27 19:31:04 Can you link me up to a good USBasp? I just checked and this one is giving me vid=0x03EB & pid=0xc8b4, while the USBasp is looking for  vid=0x16c0 & pid=0x05dc. userHeadPic MrIon
2013-11-27 14:53:20 I got the fremantics OBD II Adaptor. I want to program it using an USBASP, so I got one and connected it according to the link below: [url=http://arduinodev.com/programming-freematics-obd-ii-adapter/]http://arduinodev.com/programming-freematics-obd-ii-adapter/[/url]
userHeadPic MrIon
