Forum >I can't make the pid_speed work..
Telematics General
userHead AleEscalanteH 2014-01-15 19:10:32 4040 Views2 Replies
hi stanley
i wrote this code but i doesn't work… and its only blink the led… after i want to print the speed in kph in some java program… i will very grateful if you can help me.. thanks
(the rpm pid works fine).
#include <Arduino.h>
#include <OBD.h>
#include <Wire.h>
COBD obd;
pinMode(13, OUTPUT);
pinMode(A0, OUTPUT);
pinMode(A1, OUTPUT);
obd.begin();
while (!obd.init());
int value;
int vel;
if (obd.read(PID_SPEED, kph)){
digitalWrite(13, vel = 0 ? HIGH : LOW);
digitalWrite(A0, vel >= 100 ? HIGH : LOW);
if (obd.read(PID_RPM, value)) {
digitalWrite(A1, value > 900 ? HIGH : LOW);
2014-01-16 16:46:18 if (obd.read(PID_SPEED, [b]kph[/b])){ digitalWrite(13, [b]vel[/b] = 0 ? HIGH : LOW); digitalWrite(A0, [b]vel[/b] >= 100 ? HIGH : LOW);
Gotta pick either kph or vel as your variable
userHeadPic r0tor
2014-01-16 09:07:15 damm.... :(
well but whats wrong in the code.. the pid_speed don´t work
userHeadPic AleEscalanteH
