Forum >OBD kit keeps reconnecting
Hi there,
I have kit #2 and #3.
I am connecting the units to a 2001 Subaru STI (JDM) model.
I have the megalogger sketch as a base and have edited the code to include certain SSM protocol PID's. Even if I comment out the entire custom section of the code, the unit still keeps reconnecting.
The units start up, goes to the data screen, then just reconnects.
I figured that the reconnect function is called when errors >= 3, so I changed this to 300 just to see what happens. I am not sure what errors this refers to.
the unit then goes to the data screen, but nothing is being read from the ECU
I previously had the unit operating, pulling data from the ECU (like rpm, etc...) but now nothing is happening.
All I edited was the SSM section I added, but as said, even when editing this out, still the same action.
I2C connector.
Any ideas as to what is causing this!
I reloaded the original megalogger sketch too - no edits. and it does exactly the same thing - however, for a split second I can see 2 values pulling through, but then it reconnects / reboots.
thanks
Khaos
I2C connector.
thanks
Khaos
2014-04-21 10:14:05 interesting finding:
I plugged it into a Subaru Outback 2007 and I get data pulling through.
When I plugged it into a 2001 Subaru Impreza STI - absolutely nothing.
the only difference I can see between the 2, is that the Impreza is a 16bit ECU and the Outback is 32bit
does this matter???
thanks
Khaos
Khaos
does this matter???
thanks
Khaos
