Forum >Compiling errors of example sketch
Telematics General
userHead xl15 2013-11-28 00:00:31 7420 Views5 Replies
I'm really interested in buying one. Downloaded the examples and tried to compile rpm_led, but I got some errors:
rpm_led:13: error: 'COBD' does not name a type
If I tried with COBDI2C instead I got the same error:
rpm_led:16: error: 'COBDI2C' does not name a type
The folder is placed in Librarys as all my other ones.
2014-04-24 03:41:47 I removed the library folders from within the meggalogger folder, as per the screenshot I posted previously.
I try a few things differently every now and then but still no success.
If you could show me exactly what I need to have in the "...\Documents\Arduino\libraries\megalogger" directory I think it would resolve my issue.
Again sorry for our lack of understanding, but perhaps you could simplify this for me.
If anyone could point me in the direction of some clear instructions it would be appreciated.
Thanks in advance.
userHeadPic Auzzook
2014-04-20 23:52:39 I'm not sure I fully understand.
Perhaps you could tell me exactly what I need in the 'megalogger' folder for kit #2 with the type B OBDII adaptor, BLE and the 2.8" TFT LCD?
So far I have tried compiling with the contents of the subfolders (MPU6050, MultiLCD, OBD, and TinyGPS) copied into the "megalogger" folder. I have also tried with the "megalogger" folder as found and with the subfolders and their contents removed completely.
Do I need to rename anything within the MultiLCD to suit the 2.8" ILI9325DS TFT LCD I am using?
Note: I have also removed the .ccp and .h files for the other display types that I [u]hope[/u] were not required.
userHeadPic Auzzook
2014-04-17 04:47:20 G'day,
Firstly I am totally new to Arduino, but I received my Arduino OBD-II Data Logger Kit #2 today.
I have downloaded megalogger-src-20131211.zip and imported it into XXXX\Documents\Arduino\libraries\megalogger
I have tried uploading several times without success, and have tried moving the contents of all the subfolders to the megalogger folder.
despite this I am still getting a huge list of errors.
[code]megalogger\fonts.cpp.o:(.progmem.data+0x0): multiple definition of `digits16x24'
fonts.cpp.o:(.progmem.data+0x0): first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
megalogger\fonts.cpp.o:(.progmem.data+0x1e0): multiple definition of `digits16x16'
fonts.cpp.o:(.progmem.data+0x1e0): first defined here
megalogger\fonts.cpp.o:(.progmem.data+0x320): multiple definition of `digits8x8'
fonts.cpp.o:(.progmem.data+0x320): first defined here
megalogger\fonts.cpp.o:(.progmem.data+0x370): multiple definition of `font5x8'
fonts.cpp.o:(.progmem.data+0x370): first defined here
megalogger\fonts.cpp.o:(.progmem.data+0x546): multiple definition of `font8x16_doslike'
fonts.cpp.o:(.progmem.data+0x546): first defined here
megalogger\fonts.cpp.o:(.progmem.data+0xb16): multiple definition of `font8x16_terminal'
fonts.cpp.o:(.progmem.data+0xb16): first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::clearPixels(unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:246: multiple definition of `LCD_ILI9325D::clearPixels(unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:246: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::WriteData(unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:101: multiple definition of `LCD_ILI9325D::WriteData(unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:101: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::WriteData(unsigned char, unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:78: multiple definition of `LCD_ILI9325D::WriteData(unsigned char, unsigned char)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:78: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::SetDataMode()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:73: multiple definition of `LCD_ILI9325D::SetDataMode()'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:73: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::SetCommandMode()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:66: multiple definition of `LCD_ILI9325D::SetCommandMode()'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:66: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::WriteCommandData(unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:126: multiple definition of `LCD_ILI9325D::WriteCommandData(unsigned int, unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:126: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::setXY(unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:230: multiple definition of `LCD_ILI9325D::setXY(unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:230: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::draw4bpp(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:449: multiple definition of `LCD_ILI9325D::draw4bpp(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:449: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::draw2x(unsigned char const*, unsigned int, unsigned int, unsigned char, unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:430: multiple definition of `LCD_ILI9325D::draw2x(unsigned char const*, unsigned int, unsigned int, unsigned char, unsigned char)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:430: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::draw(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:415: multiple definition of `LCD_ILI9325D::draw(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:415: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::writeDigit(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:349: multiple definition of `LCD_ILI9325D::writeDigit(unsigned char)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:349: first defined here
megalogger\ILI9325D.cpp.o: In function `non-virtual thunk to LCD_ILI9325D::write(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:464: multiple definition of `non-virtual thunk to LCD_ILI9325D::write(unsigned char)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:464: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::write(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:285: multiple definition of `LCD_ILI9325D::write(unsigned char)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:285: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::clear(unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:263: multiple definition of `LCD_ILI9325D::clear(unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:263: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::Disable()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:62: multiple definition of `LCD_ILI9325D::Disable()'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:62: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::Enable()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:61: multiple definition of `LCD_ILI9325D::Enable()'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:61: first defined here
megalogger\ILI9325D.cpp.o: In function `LCD_ILI9325D::begin()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9325D.cpp:134: multiple definition of `LCD_ILI9325D::begin()'
ILI9325D.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9325D.cpp:134: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::clearPixels(unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:371: multiple definition of `LCD_ILI9341::clearPixels(unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:371: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::backlight(bool)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:368: multiple definition of `LCD_ILI9341::backlight(bool)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:368: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::WRITE_Package(unsigned int*, unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:85: multiple definition of `LCD_ILI9341::WRITE_Package(unsigned int*, unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:85: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::sendData(unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:74: multiple definition of `LCD_ILI9341::sendData(unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:74: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::WRITE_DATA(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:66: multiple definition of `LCD_ILI9341::WRITE_DATA(unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:66: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::sendCMD(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:58: multiple definition of `LCD_ILI9341::sendCMD(unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:58: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::setPage(unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:279: multiple definition of `LCD_ILI9341::setPage(unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:279: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::setCol(unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:272: multiple definition of `LCD_ILI9341::setCol(unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:272: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::setXY(unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:353: multiple definition of `LCD_ILI9341::setXY(unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:353: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::setPixel(unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:360: multiple definition of `LCD_ILI9341::setPixel(unsigned int, unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:360: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::draw2x(unsigned char const*, unsigned int, unsigned int, unsigned char, unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:558: multiple definition of `LCD_ILI9341::draw2x(unsigned char const*, unsigned int, unsigned int, unsigned char, unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:558: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::draw(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:539: multiple definition of `LCD_ILI9341::draw(unsigned char const*, unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:539: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::clear()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:330: multiple definition of `LCD_ILI9341::clear()'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:330: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::clear(unsigned int, unsigned int, unsigned int, unsigned int, unsigned int)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:286: multiple definition of `LCD_ILI9341::clear(unsigned int, unsigned int, unsigned int, unsigned int, unsigned int)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:286: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::Read_Register(unsigned char, unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:103: multiple definition of `LCD_ILI9341::Read_Register(unsigned char, unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:103: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::readID()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:244: multiple definition of `LCD_ILI9341::readID()'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:244: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::writeDigit(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:458: multiple definition of `LCD_ILI9341::writeDigit(unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:458: first defined here
megalogger\ILI9341.cpp.o: In function `non-virtual thunk to LCD_ILI9341::write(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:590: multiple definition of `non-virtual thunk to LCD_ILI9341::write(unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:590: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::write(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:385: multiple definition of `LCD_ILI9341::write(unsigned char)'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:385: first defined here
megalogger\ILI9341.cpp.o: In function `LCD_ILI9341::begin()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/ILI9341.cpp:117: multiple definition of `LCD_ILI9341::begin()'
ILI9341.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/ILI9341.cpp:117: first defined here
megalogger\LCD4Bit_mod.cpp.o: In function `LCD4Bit_mod::pulseEnablePin()':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/LCD4Bit_mod.cpp:40: multiple definition of `LCD4Bit_mod::pulseEnablePin()'
LCD4Bit_mod.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/LCD4Bit_mod.cpp:40: first defined here
megalogger\LCD4Bit_mod.cpp.o: In function `LCD4Bit_mod::pushNibble(unsigned char)':
E:\Users\Simon\Documents\Arduino\libraries\megalogger/LCD4Bit_mod.cpp:52: multiple definition of `LCD4Bit_mod::pushNibble(unsigned char)'
LCD4Bit_mod.cpp.o:E:\Users\Simon\AppData\Local\Temp\build8566799102233160765.tmp/LCD4Bit_mod.cpp:52: first defined here
megalogger\LCD4Bit_mod.cpp.o: In function `LCD4Bit_mod::pushByte(unsigned char)':
[/code]
Please refer to the attached screenshot of the meggalogger folder, as I have a feeling I am missing something from here.
Thanks in advance,
userHeadPic Auzzook
2013-12-19 12:26:12 Can someone please let me know exactly what the correct location for the all the files are because I still get 'COBD' does not name a type.
I downloaded two .ino files, one .cpp, and .h file from https://github.com/stanleyhuangyc/ArduinoOBD/tree/master/libraries/OBD
I tried putting obd.h and obd.cpp into a folder called obd under libraries in my Arduion 1.5.2 directory and in the 1.0.5 directory - and I moved the .ino's into the examples folder.  I still get the error.  I've already bought the kit, but haven't been able to get it up and running.
Thanks in advance for any help.
userHeadPic gibbsji
2013-11-29 01:53:13 I unzipped the file, placed the folder in "libraries" togheter with all my other libraries and renamed it to ArduinoOBD.
Didn't realize I had to move the "OBD" folder too.
Sorry, it works now and I will order an adapter :)
userHeadPic xl15
