Forum > How to make the SD card socket on the TFT LCD shield work with Arduino MEGA 256
Telematics General
userHead tomansbro 2014-01-28 17:16:36 14510 Views19 Replies
Go to <Arduino Dir>/libraries/SD/utility, open Sd2Card.h file, find and uncomment following line:
#define MEGA_SOFT_SPI 1
My Sd2Card.h file has #define MEGA_SOFT_SPI 0
If I change the 0 to 1 I get the error
C:\ Program files\arduino...\utility\Sd2card.cpp:585: error: 'SPI' was not declared in this scope
what am I doing wrong?
2014-05-12 23:04:06 Hi again orpheus88,
I've already try to format using the FAT32, it seems to be fine when the kit still connected with my computer but after i plugged in to the obd car the display on the LCD kit listed as "no sd card", still the same problem.
Can you share your program sir? many thanks before.
userHeadPic DonJuan
userHeadPic DonJuan
2014-05-07 05:55:45 How do I read an analog input voltage on A0 (First pin of the analog header) and transmit the value over Bluetooth, do you have a simple example of this. userHeadPic MelvinOdellTucker
2014-05-07 00:03:10 [quote="DonJuan"]
Wich forum sir?
Thanks for the info, i'll try to format again using FAT32.
[/quote]
[url=http://freematics.com/forum/viewtopic.php?f=4&t=3]http://freematics.com/forum/viewtopic.php?f=4&t=3[/url]
But seems to be approved posting, which is probably why there are like no posts.
userHeadPic orpheus88
Wich forum sir?
[/quote]
2014-05-06 23:42:05 Wich forum sir?
userHeadPic DonJuan
userHeadPic DonJuan
2014-05-06 03:34:22 In another forum stanley wrote you should use FAT32 and thats also what my cards, that work in the Freematics adapter, are formated with. userHeadPic orpheus88
2014-05-05 21:23:36 Hello tomansbro,
I wanna ask about the format, what format are you using? FAT16? FAT32?
I've tried with the FAT16, and it works fine at the first it can tell how much space the memory left, but after i plugged in to the obd connector in the car, it shows up "NO FAT" result.
Any info or help about that please.
userHeadPic DonJuan
userHeadPic DonJuan
2014-02-13 17:11:30 Thanks for sharing!
I Will try it.
Cheers
userHeadPic Jose
I Will try it.
Cheers
userHeadPic Jose
2014-02-12 15:26:24 After lots of trial and error, I decided to try on a new machine.  Success!! apparently my libraries were corrupt.
Back to the first machine, uninstalled EVERYTHING, reinstalled IDE & Libraries and JOY!!  working as designed.
userHeadPic tomansbro
2014-01-31 07:05:47 Thank you Stanley,
  After reinstalling IDE and Libraries the sketch compiles with no errors.  I have edited config.h and  Sd2card.h as posted in the FAQ. but still no Joy.. NO SD CARD ....the card is formatted as fat 32 I tried another one formatted as Fat...What else can I try?
Thanks for all your help!
Tom
Tom
2014-01-28 17:16:36 Go to <Arduino Dir>/libraries/SD/utility, open Sd2Card.h file, find and uncomment following line:
