Forum >avrdude error
avrdude error
I received my logger kit #1 yesterday and I've been trying to upload some code to it. No matter what software I use to upload the code I get this error:
avrdude: stk500_getsync(): not in sync: resp=0x00
I've been googling and reading everything that I can about this problem.
[url=http://forum.arduino.cc/index.php?PHPSESSID=tfio6lsmm93m6743pdl9ph73o5&topic=166294.45]http://forum.arduino.cc/index.php?PHPSESSID=tfio6lsmm93m6743pdl9ph73o5&topic=166294.45[/url]
[url=http://electronics.stackexchange.com/questions/69224/arduino-nano-v3-atmega-328p-avrdude-stk500-getsync-not-in-sync-resp-0x00]http://electronics.stackexchange.com/questions/69224/arduino-nano-v3-atmega-328p-avrdude-stk500-getsync-not-in-sync-resp-0x00[/url]
[url=http://forum.arduino.cc/index.php?topic=210565.0]http://forum.arduino.cc/index.php?topic=210565.0[/url]
I'm using a 2011 MBP dual booted to windows 7 64bit.
I have tried 2 different wires and both of the ports.
I tried the loop-back test and it failed.
The last thing I've done is set up everything like in the top post from the first link.
Does anyone have any ideas? I do have an arduino uno if that could possibly help? The UNO works when I program it with the traditional arduino software but it will get 90% with the arduino builder software. The error is avrdude.exe: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
2014-05-28 19:10:55 That's what I did. I think the board is defective. Who should I call or email to talk about a refund or to get a new board.
ateevg
2014-05-23 18:53:59 I wasn't able to burn the bootloader: avrdude: stk500_recv(): programmer is not responding
[url=http://sysexit.wordpress.com/2013/02/07/burning-a-bootloader-to-an-arduino-nano-using-another-arduino/]http://sysexit.wordpress.com/2013/02/07/burning-a-bootloader-to-an-arduino-nano-using-another-arduino/[/url]
I used this tutorial.
ateevg
2014-05-23 18:17:19 I tried it on another computer and I got the same error :-\
I'll try burning the bootloader again.
ateevg
2014-05-22 23:40:18 ateevg,
Could be something else, so trying tomorrow on another computer might be good starting point to discard the possibility of wrong driver / software settings.
Have you tried changing the bootloader as instructed on one of the posts?
Jose
2014-05-22 23:20:16 1) I did connect it to the correct serial port
2) I've tried two different usb cables
3) I will have access to another computer tomorrow but I've tried this on both the mac and windows side and ran into the same problem.
4) I don't think I've changed any of the AVR settings but with all of the changes I've made that is a possibility. How can I do a complete reinstall of the AVR software?
ateevg
2014-05-22 22:07:56 Do you have a spare usb cable around and another computer?
A quick test on another machine with another cable could discard a lot of possible things.
Is it possible your AVR software is "broken" ? Did you change any avr settings manually?
[quote="ateevg"]
[/quote]
What do you mean you get 90% ?
90% upload and then fails? ( confirm this is with UNO and standalone. no other stuff plugged in )
Jose
[quote="ateevg"]
[/quote]
2014-05-22 21:44:20 Check you Serial Port under Tool->Serial Port. Did you connect to the correct Serial Port?
visualxl
