Forum >HCHO sensor with Hardware Serial
userHead Account cancelled 2018-07-16 17:45:57 1496 Views1 Replies
Do you have an example of the HCHO sketch that is working with Hardware serial. I would like to use it on an adafruit feather 32u4 which has serial built in. Thanks
2018-07-19 23:21:55 What HCHO sensor do you mean? if use hardware serial, it is easier than the software serial, normally just do some change in the code. userHeadPic robert.chen
