Forum >Help I need information on wiring positions
RoboticsGeneral
userHead moses58 2011-01-19 18:53:40 18651 Views19 Replies
Hi I purchased this DFRobot kit but I can find no intructions on where to plug
the motor encoder wires into the microcontrolor. Can anyone help?
DFRobot - HCR-Mobile robot platform ?Romeo Controller board (Arduino compatible)
DFRobot DC Motor Specifications
?Working voltage: 12V
?No load speed:8100RPM
?RPM :120RPM
?Diameter:30mm
?Length:42mm
?Nominal output power:17W
?No load current: 75mA
?Load current?1400mA
?Gearbox ratio:66:1
?Encoders:Optical
?Encoder Phase:AB
?Encoder Resolution:12CPR
2013-06-14 00:34:39 [quote="kevining"]
I recently acquired the HCR robot, and am having trouble getting it up and running. The instructions/diagrams I've found don't quite match, wondering if anyone can help.
The encoders I have are different than above, the wire colors are: black, red, yellow, green, blue, orange. (There are two motors/encoders, so there are two sets of wires). Wondering if anyone has a diagram of how to hook it all up.
Thanks!
[/quote]
Hi kevining, I am sorry for the problem of the wire colors, we will fix it later. and I think the following site maybe can help you. [url=https://www.dfrobot.com/index.php?route=product/product&path=47_110&product_id=777#.UbmAAnSS2Uk]https://www.dfrobot.com/index.php?route=product/product&path=47_110&product_id=777#.UbmAAnSS2Uk[/url]
and the new wiki of HCR will be released soon.
Pepin
userHeadPic pepin
Thanks!
[/quote]
Pepin
userHeadPic pepin
2013-06-12 21:32:15 I recently acquired the HCR robot, and am having trouble getting it up and running. The instructions/diagrams I've found don't quite match, wondering if anyone can help.
Thanks!
userHeadPic kevining
Thanks!
2011-01-27 19:32:59 I draw the diagram. And I believe it will be helpful to u.
;D
userHeadPic Lauren
;D
userHeadPic Lauren
2011-01-26 18:47:16 Thankyou you have been a big help we got it going. Could you tell me where you got the last picture? I would like to find my answers without bothering people if possible. Diagrams like this would make all the difference. userHeadPic moses58
2011-01-25 02:32:02 ;) userHeadPic Lauren
2011-01-24 07:11:00 :P
Connect the A pin of the encoder to the digital pin 2 of the Romeo.
Connect the B pin marked 4 to the digital pin 4 of the Romeo.
And also you can click the image to enlarge.
userHeadPic Lauren
userHeadPic Lauren
2011-01-23 18:20:10 Well it is just my luck the encorder wires are different. I have brown, grey, white and black. I can find no help on how to connect these wires to the board. All attempts to find a answer on the internet have failed. Is there anyone who has made this HCR-Mobile robot platform with sensors and microcontroller robot platform?
•Two 17w DC motors with 64:1 Gearbox 120 rpm
•Two (2 Phases) encoders with 12 PPR
•Romeo Controller board (Arduino compatible)
Can someone send a better picture or explination?
[email protected]
userHeadPic moses58
[email protected]
userHeadPic moses58
2011-01-20 12:04:06 Thank you for the photo and code.  I am visually impaired so the photo is a little to far away for my friend to clearly see the wire colors.  We will try to make do. Thanks userHeadPic moses58
2011-01-19 20:10:21 Hi.
Connect the encoder according to the picture.
The sample code:
[code]
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 4;//B pin -> the digital pin 4
byte encoder0PinALast;
int duration;//the number of the pulses
boolean Direction;//the rotation direction
  Serial.begin(57600);//Initialize the serial port
  EncoderInit();//Initialize the module
  Serial.print("Pulse:");
  Serial.println(duration);
  duration = 0;
  delay(500);
void EncoderInit()
  Direction = true;//default -> Forward
  pinMode(encoder0pinB,INPUT);
  attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
  int Lstate = digitalRead(encoder0pinA);
  if((encoder0PinALast == LOW) && Lstate==HIGH)
    int val = digitalRead(encoder0pinB);
    if(val == LOW && Direction)
      Direction = false; //Reverse
    else if(val == HIGH && !Direction)
      Direction = true;  //Forward
  encoder0PinALast = Lstate;
  if(!Direction)  duration++;
  else  duration--;
[/code]
userHeadPic Lauren
The sample code:
[code]
  duration = 0;
  delay(500);
void EncoderInit()
void wheelSpeed()
  else  duration--;
[/code]
userHeadPic Lauren
2011-01-19 18:53:40 Hi I purchased this DFRobot kit but I can find no intructions on where to plug
?RPM :120RPM
?Diameter:30mm
?Length:42mm
?Gearbox ratio:66:1
?Encoders:Optical
?Encoder Phase:AB
userHeadPic moses58
