URM06 and URM07 ultrasonic sensors
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
Anybody here if have used URM07 and URM06 ultrasonic sensors , please let me known
1) Are they compatible with Arduino
2) Does URM 07 is efficient till 10m and URM 06 is till 7.5m
I have gone through their datasheets , and I am thinking to use these for my project work. So, please let me know are they reliable enough to use.
2018-07-24 14:27:31 Ty sir for your kind reply.
Yes it may affect due to external factors. But suppose the surface is smooth and it is not giving 10m , no doubt, but can I t give up to 7 m.
And also can I integrate both URM06 and URM07 as both have different detecting angle.
rahul.lindayat
![userHeadPic](https://dfimg.dfrobot.com/dfPortrait2.png)
2018-07-19 15:09:11 1. Both ultrasonic sensors are compatible with Arduino, you can find the usage from the wiki of the products
2. The efficient distance you can refer to the datasheet, but this is the theoretical range, the measurement distance is affected by many factors, like the material of the target, the area of the target etc. so the efficient distance here is not a practical distance.
robert.chen
