Forum >GMR cables
GMR cables
Where can I find cables for the GMR board?
2014-04-23 23:23:33 The 4PIN headers for the encoders come with the encoder adapter kit. So no wire fix is required.
However for the 6PIN what i would do is to solder them on the back of the board. Or get the header from your local electronics supplier and crimp it. Perhaps they have a wire with this header already that you can use.
I like the soldering idea because is quick if you have a soldering station nearby, and the motor driver pins used on the wiki example has standard jumper wires, so just the female jumper wire header is required.
Jose
2014-04-23 18:11:17 Thanks for the idea. I was thinking about something similar for those connections having three pins but the four and six pin connections are more problematic. How did you deal with those?
owize1
2014-04-21 22:34:19 Welcome Owize!
These cables are unavailable for the time being, so for now we just provide this solution:
[url=https://www.dfrobot.com/index.php?route=product/product&filter_name=pin&page=3&product_id=391#.U1S7PlVdVKB]https://www.dfrobot.com/index.php?route=product/product&filter_name=pin&page=3&product_id=391#.U1S7PlVdVKB[/url]
Here are a couple of pictures on how I've connected mine.
Jose
