Forum >OBD2 SKU TEL0068
OBD2 SKU TEL0068
Sorry for the stupid question, but I just received my OBD2 diagnostic cable in the mail (TEL0068) and I can't figure out which pins to plug which wires into. I have the VCC and the GND, but I'm not sure which colored wires go into which pins on the Arduino UNO. I'm hoping to use this cable for our entire fleet of vehicles (100+) if this proof of concept works out.
Thanks!
Thanks!
2013-11-19 06:12:30 Thanks for the reply but I've looked at that and all I've seen is that Blue goes to SDA and Yellow SCL. The uno has two of each and I don't know where the accelerometer wires go (since this is model B).
Is there some direct way to contact Stanley or should I just be patient for a response from him on this forum. Either one is fine with me, I just want to make sure I'm doing the right thing.
Thanks!
gibbsji
Thanks!
2013-11-18 21:57:48 i'm not sure if its the same version, but check out this link see if it helps:
http://arduinodev.com/hardware/obd-kit/
There is some wiring information there, Stanley certainly knows more about it
Jose
