Forum >Connections to Motors on 4 WD Platform
RoboticsGeneral
userHead Account cancelled 2011-02-08 11:51:23 6358 Views3 Replies
Unfortunately my soldering skills are not so good. I have managed to snap off the leads to the motors. I took them apart and found a small bent lead which is the brush. I am wondering if there is any way to repair these motors?
I am also wondering if you might be kind enough to suggest a way of soldering or if there is an alternative such as clips that could be crimped over the motor leads or some other method. I have bought several sets of these motors but find the leads break off if I apply too much heat. It is a shame and I would like to continue with this kit since I bought the controller board from you as well. Please consider helping?
Henry Staub
2022-02-18 00:16:04 4WD platform not easy to form specially if you want exact platform that same has reupdated companies wheel spin in 4WD also matters in all the scenario you ask the right question userHeadPic bhuteshkumar
2021-10-09 17:28:29 My desire to have someone to do my homework for me cheap has been a long-held dream. Homeworkfor.me are true professionals who have made that possible. It's fast, secure, anonymous, reliable, and reliable. userHeadPic sophieturner726
2011-02-09 08:03:10 Hello,
I am hopeless with soldering as well and those motor leads do look fragile, that's why I chose not to bother and just twisted the wires to motor leads. It does not look nice but it does not break anything either.
I thought you might want to consider these:
http://oomlout.dfrobot.uk/jumper-wires-wcrocodile-clips-x10-p-239.html
, or search on eBay for crocodile clips.
If you do need replacement motors, these are available separately and also quite cheap:
https://www.dfrobot.com/index.php?route=product/product&path=47&product_id=100
Just to clarify, I am not affiliated with DFrobot.
userHeadPic fj604
