Forum >Cannot get BMP280 sensor working
I have purchase a 10DOF IMU sensor for DFRobot. Following the steps from https://www.dfrobot.com/wiki/index.php/ ... U:_SEN0140 I managed to get the accelerometer, gyro and compass data, but the barometer is not initialising. The message I received by using the sketch from there is:
"Could not find a valid BMP280 sensor!"
Could you please provide some information to fix this issue?
Many thanks,
minu
Many thanks,
minu
2018-08-02 00:57:22 What is the Arduino board you used. If the code uploaded correctly, it should be able to find the sensor.
robert.chen
