Forum >Making connection to FIT0333 flexible solar panel
Can anyone suggest how to make the electrical connections to the FIT0333 flexible solar panels? I've already cooked one trying (low temperature) soldering to the small rings on the back of the device. Not sure what else is possible. Thanks, Ed
2018-08-02 21:33:12 You can solder two wires from the panel and connect it to a battery charger to charge the battery.
robert.chen
