Forum >FIT0482 encoder minimum voltage?
RoboticsGeneral
userHead brianj 2018-07-26 08:40:50 3440 Views3 Replies
Hello, the encoder pinout diagram for this motor only shows a VCC of "3.3V/5V", but can you provide more detailed specs on that power rail options? Such as how low can it really go and still operate reliably? We're running our VCC system at 2.5V (including our MCU) and want to run the encoder at the same VCC level. Is that ok? Can you provide a datasheet or more detailed specs on the encoder part?
Thanks!
Brian
2018-08-18 20:49:10 Thanks. Can you please provide a datasheet for that encoder? userHeadPic brianj
2018-08-02 02:39:22 Because most of the Arduino board work under 3.3 or 5V, this encoder can work under 3.3V as the lowest voltage, 2.5V may not available to use for this encoder. userHeadPic robert.chen
2018-07-31 12:38:45 Well, that reply wasn't very helpful. Any other better responses out there? Thx. userHeadPic brianj
