Forum >5-DOF Robotic Arm
RoboticsGeneral
5-DOF Robotic Arm
userHead SuperMiguel 2011-09-17 07:01:22 5607 Views1 Replies
Is there an assembly guide/code example on the 5-DOF Robotic Arm ??
2011-09-19 18:17:52 Hi SuperMiguel,
You can follow this video to see the assembly process. Just ignore the "Base" construction part, that is for the 6 DOF.
[URL=http://youtu.be/1oV0RMaZcms] 6 DOF assembly [/URL]
As far as sample code we don't have any for you. But it should be very simple to get it working.
If you want to use the arduino just need to assign the Servos an address and tell them to move the appropriate amount when you want.
Otherwise you can use a servo controller and windows to move the servos the way you want.
Here is our [URL=https://www.dfrobot.com/index.php?route=product/product&filter_name=32%20servo%20controller&product_id=382] servo controller board[/URL]
Hector
userHeadPic Hector
