Forum >Bluno: error: 'Serial' was not declared in this scope
Bluno General Arduino
userHead Account cancelled 2018-08-02 04:58:22 2034 Views1 Replies
Hi!
I am new to Arduino, and I am trying to run a very simple code on Bluno.
I use Macbook with Arduino IDE, and connect the Bluno via USB. I can tell that it is somewhat working, as the 'Blink' example works for me.
However, if I try using any of the Serial commands, I get the following error:
example:31: error: 'Serial' was not declared in this scope
if (Serial.available())
Is there anything I need to include to make this work?
I found out that if I use SerialX for X in {1, 2, 3, 4, 5}, it uploads without errors. However, all calls to SerialX.available() return false.
2018-08-02 19:37:44 Bluno only has one serial, there should not be Serial1 or Serial2 etc. Could you provide the code you use? userHeadPic robert.chen
