Forum >just a question
RoboticsGeneral
just a question
userHead abdulaziz.alqurashii 2018-08-05 08:04:47 4776 Views3 Replies
Hello, how are you
I do not know if this is the right place to ask but I wanted to ask if I could use this dc motor with the raspberry pi directly or not ??
https://www.dfrobot.com/product-777.html
2018-08-29 01:41:51 Yes, A & B are the hall sensor Vout, you can connect to GPIO on Raspberry pi. userHeadPic robert.chen
2018-08-07 02:15:29 Thanks for your answer, but this motor has a encoder and encoder adapter
and the encoder adapter has 4 wires
1- GND
2- Vcc
3- A
4- B
what means by A and B (I think as I read A and B are Vout the square wave output ,and can i connect A and B to raspberry pi )
userHeadPic abdulaziz.alqurashii
2018-08-07 01:18:55 This is a 12V motor, you can use an Rpi to control it, but you may need an external power and an motor driver like L298N userHeadPic robert.chen
