Forum >NB-IOT SIM7000 Arduino Shield TurnOn Problem
Hi,everyone
I use NB-IOT SIM7000 Shield to do my project.
When I try to use example code on this website
https://github.com/DFRobot/DFRobot_SIM7000
I always get Turn ON SIM7000......
The module seems cannot turn on even I give 9V power supply.
Can anyone help me?
Can anyone help me?
2019-02-22 01:54:53 Power: for now shield is plugged into my Arduino Uno (shield pins to Arduino pins). Arduino is connected to my PC with USB A-B. I think there is no problem with power supply, because NB-IOT SIM7000 module is able to get data from BME 280 sensor.
Provider: I bought standard SIM card with 30gb internet data package. Provider is Play - polish cellular telecommunications provider.
kaczmarek.mateusz.dev
2019-02-21 18:16:04 How do you power this module? Did you use an external power? Because it needs enough power.
robert.chen
robert.chen
robert.chen
robert.chen
2019-02-18 21:33:57
Can I know which country are you in?
robert.chen
Hikaczmarek.mateusz.dev wrote: āFri Feb 15, 2019 3:43 pmHello,
I have same problem with my NB-IOT SIM7000E Arduino Shield ;/
Here s my code:Code: Select all
#include <Wire.h> #include <DFRobot_SIM7000.h> #define PIN_TX 7 #define PIN_RX 8 SoftwareSerial mySerial(PIN_RX,PIN_TX); DFRobot_SIM7000 sim7000; void setup(){ Serial.begin(115200); while(!Serial); Serial.println("BEFORE begin()"); sim7000.begin(mySerial); Serial.println("AFTER begin()"); Serial.println("BEFORE turnON()"); sim7000.turnON(); Serial.println("AFTER turnON()"); } void loop(){ Serial.println("INSIDE LOOP"); }
It always stops on printing 'BEFORE turnON()' - turnON() method seems not to work correctly.
I have Software/Hardware Port switched to Tx->D8, Rx->D7,
SIM card is inside the socket,
GNSS & GSM/LTE antenas are plugged in.
No idea what I am doing wrong, anyone can help here?
2019-02-18 21:33:57
robert.chen
2019-02-18 21:33:57
robert.chen
2019-02-18 21:33:57
robert.chen
2019-02-16 07:43:39 Hello,
Here s my code:
Here s my code:
Here s my code:
Here s my code:
Here s my code:
Here s my code:
Here s my code:
Here s my code:
