Forum >Customize Baron-4WD
RoboticsGeneral
Customize Baron-4WD
userHead robb83 2012-06-15 14:46:25 4420 Views1 Replies
Hi!
[url=http://www.dfrobot.com/index.php?route=product/product&product_id=261]http://www.dfrobot.com/index.php?route=product/product&product_id=261[/url]
It is possible to replace battery holder?
For this one: [url=http://www.dfrobot.com/index.php?route=product/product&path=70&product_id=500]http://www.dfrobot.com/index.php?route=product/product&path=70&product_id=500[/url]
And other hand:
Which motor controller is recormmended?
[url=http://www.dfrobot.com/index.php?route=product/product&keyword=DRI0002&category_id=0&description=1&model=1&product_id=66]http://www.dfrobot.com/index.php?route=product/product&keyword=DRI0002&category_id=0&description=1&model=1&product_id=66[/url]
[url=http://www.dfrobot.com/index.php?route=product/product&filter_name=2a&product_id=69]http://www.dfrobot.com/index.php?route=product/product&filter_name=2a&product_id=69[/url]
Thx for answare!
2012-06-15 19:51:22 Hi Robb,
You can purchase the other battery holder and use that one instead.
As far as motor controller. You could use the [url=https://www.dfrobot.com/index.php?route=product/product&filter_name=romeo&product_id=656]Romeo[/url] which is an Arduino compatible microcontroller with a motor controller integrated.
Or either of the 2 motor controllers you were looking at will also work fine. It just depends on your desired arrangement. The shield will offer a more compact solution, while the module would allow you to place it in a different location.
userHeadPic Hector
