Forum >Romeo BLE rebooting with Devastator Mobility Platform
RoboticsGeneral
userHead dsuch 2018-09-02 00:10:28 4183 Views3 Replies
I have the same problem as another poster.
The Romeo BLE is mounted in your Devastator tank mobility platform. It is being remotely controlled via BLE using a mobile. Everything works as expected as long as you don't drive the motors over about 50% (i.e. motor duty cycle > 50%).
I'm monitoring the current to one of the motors using a INA219 and it isn't showing anything dramatic.
25% Duty Cycle: 287 mA
50% Duty Cycle: 414 mA
I'm also monitoring the battery voltage (9V) using a voltage divider (2 x 10k resistors). I think this is where the issue may be.
25% Duty Cycle: 8.75 V
50% Duty Cycle: 7.77 V
I suspect that when the motors are driven greater than 50% duty cycle the voltage is going low enough to trip the Romeo brown out protection.
Is there anyway to power the microprocessor separately from the motors? I had a look at the schematic for the Romeo BLE and there doesn't seem to be any way.
2018-09-12 23:40:00 I can still enter AT mode via the BLE link - but that seems to be it. I reset the settings to default via this but still no joy trying to upload a sketch or view a response in the serial monitor. I checked the UART settings and they are correct. Any ideas gratefully accepted. userHeadPic dsuch
2018-09-12 23:06:43 I read that updating the boot loader to v2 can help, so I tried that. Now I can't connect via serial at all. sigh... userHeadPic dsuch
2018-09-04 23:58:18 No ideas? userHeadPic dsuch
