Forum >RS485 Shield for Arduino
As I understand the things, the Arduino doesn't have RS485 built in.
I have one of these: https://goo.gl/PTaKo5 - a RS485 relay.
But I can't quite get it to work with the shield I bought.
Will the board or the Arduino itself be able to send commands through RS485 to the relay?
An example of the command: "01 06 00 01 01 00 D9 9A".
Or do I need a completely other board?
2018-09-06 05:06:37
But I couldn't get the confirmation on that it can be used.
And will it be possible to change the pin from 0 and 1, since that I'm using those for usb to pc.
renedyhr
That's the one that I have.robert.chen wrote: ↑Tue Sep 04, 2018 10:29 amHave you consider to use the RS485 shield? https://www.dfrobot.com/product-1024.html
2018-09-05 02:29:39 Have you consider to use the RS485 shield? https://www.dfrobot.com/product-1024.html
robert.chen
2018-09-05 00:08:44
renedyhr
Will it not be possible to use the Arduino in some way with either the board I got or built in the Arduino?
2018-09-04 19:17:19 Hi
If you want to control the relay by RS485 communication protocol.You should use the STMicroelectronics 32bits series developments board, It supports RS485.Hope help you.
makermuyi
