Vehicle Speed Sketch using Can-Bus Shield
I am using the can bus shield and I can find sketches for rpm and vin number and both work what I am seeking is a sketch example for vehicle speed in klms taken from the CAN-BUS data
If anyone can point me in the right direction I would really appreciate it.
The CAN-BUS shield is mounted on an arduino Mega board
Thanks in advance
Regards
Claude
Thanks in advance
Regards
Claude
2018-09-17 10:24:58 Hi.
You can use the Gravity: 360 Degree Hall Angle Sensor https://www.dfrobot.com/product-1553.html measuring vehicle speed. makermuyi
