Forum >DFRobot Bluetooth V3 + Romeo V2
RoboticsGeneral
userHead ML 2013-09-22 06:21:51 28307 Views39 Replies
Hey ;)
I'm using Romeo v2 and i want to set up Bluetooth v3. is it possible to set it up without USB-TTL Converter?
2013-10-08 22:13:30 Yeah, almost like this
do you use the Arduino mega? it depands on which serial port you use
serial means rx0 and tx0
serial1 means dfrobot and tx1
userHeadPic Grey.CC
userHeadPic Grey.CC
userHeadPic Grey.CC
userHeadPic Grey.CC
2013-10-08 21:45:01 [quote="Grey"]
Hello, nepekyp
you can write the AT command in the code and use the Arduino to write it into the bluetooth bee through serial port.
[/quote]
Something like that?
Serial.begin(9600);
Serial.print("AT");
void loop
Which Serial i must use? Serial or Serial1
userHeadPic nepekyp
Hello, nepekyp
[/quote]
Serial.begin(9600);
Serial.print("AT");
void loop
userHeadPic nepekyp
Hello, nepekyp
[/quote]
Serial.begin(9600);
Serial.print("AT");
void loop
userHeadPic nepekyp
Hello, nepekyp
[/quote]
Serial.begin(9600);
Serial.print("AT");
void loop
userHeadPic nepekyp
2013-10-08 21:01:17 Hello, nepekyp
userHeadPic Grey.CC
userHeadPic Grey.CC
userHeadPic Grey.CC
userHeadPic Grey.CC
2013-10-07 21:12:51 [quote="Jose"]
You could use arduino to input the AT commands to the bluetooth module. and if the At commands returns OK blink the LED or something like that.
[/quote]
How i can do that?
Do i need something sketch for arduino? (Leonardo v2 r3)
userHeadPic nepekyp
[/quote]
How i can do that?
userHeadPic nepekyp
[/quote]
How i can do that?
userHeadPic nepekyp
[/quote]
How i can do that?
userHeadPic nepekyp
2013-10-02 04:16:20 Thanks for your advise. I've decided to buy the converter. Seems like a better choice. :)
Best
Marti
userHeadPic ML
Best
Marti
userHeadPic ML
Best
Marti
userHeadPic ML
Best
Marti
userHeadPic ML
