Forum >Cherokey 4WD work with Wirless GamePad V2.0 (Xbee)
Hello!
I've bought Cherokey 4WD with 2 Xbee and Wirless GamePad V2.0, where can I find any sketch to use this Wirless GamePad V2.0 with xbee to work with Cherokey 4WD?
I mean sketch for gamepad to control the Cherokey 4WD, not just the sketch to show the what button I pressed and show it on the serial minor.
Any help would be greatly appreciated!
2013-11-05 08:18:33 [quote="Grey"]
Hi Tony,
Could you provide your xbee link?Because different type of xbee has different setting.
Whether it is TEL0014?
If it was, that will be very easy.
Do you have a xbee usb adapter? And a software named"X-CTU" to set the parameter.[url=http://www.digi.com/support/productdetail?pid=3352]http://www.digi.com/support/productdetail?pid=3352[/url]
Here is a wiki about how to do.
[url=https://www.dfrobot.com/wiki/index.php/Xbee#Connecting_your_robot]https://www.dfrobot.com/wiki/index.php/Xbee#Connecting_your_robot[/url]
[/quote]
Hi, grey,
I'm a afraid to say that I'm not using TEL0014, instead I'm using " XBee 1mW Chip Antenna (TEL0060 )". And I'm using "XBee USB Adapter V2" to connect two xbee to pc by using X-CTU software.
faweiz
Hi Tony,
[/quote]
Hi, grey,
Hi Tony,
[/quote]
Hi, grey,
faweiz
Hi Tony,
[/quote]
Hi, grey,
Hi Tony,
[/quote]
Hi, grey,
faweiz
Hi Tony,
[/quote]
Hi, grey,
Hi Tony,
[/quote]
Hi, grey,
faweiz
Hi Tony,
[/quote]
Hi, grey,
Hi Tony,
[/quote]
Hi, grey,
faweiz
Hi Tony,
[/quote]
Hi, grey,
2013-11-04 19:31:02 Hi Tony,
Grey.CC
Grey.CC
Grey.CC
Grey.CC
Grey.CC
2013-11-02 22:05:47 [quote="Grey"]
Hi Tony
I think the receiver code has a little problem. It is no necessary to define the buttons for cherokey.
You know when you press buttons on gamepad, it will display the command in the Serial port.
And cherokey just receive the command,
For example , you define "up" as "6". When you press "up" , in the Serial port it shows "6".Then your cherokey receive "6" as command
Using "switch" command, when it receives "6" it will be set to move upward.
[code]int E1 = 5; //M1 Speed Control
int E2 = 6; //M2 Speed Control
int M1 = 4; //M1 Direction Control
int M2 = 7; //M1 Direction Control
void stop(void) //Stop
digitalWrite(E1,0);
digitalWrite(M1,LOW);
digitalWrite(E2,0);
digitalWrite(M2,LOW);
void advance(char a,char b) //Move forward
analogWrite (E1,a); //PWM Speed Control
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
void back_off (char a,char b) //Move backward
analogWrite (E1,a);
analogWrite (E2,b);
void turn_L (char a,char b) //Turn Left
analogWrite (E1,a);
analogWrite (E2,b);
void turn_R (char a,char b) //Turn Right
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
Serial.begin(9600); //Set Baud Rate
Serial.println("Run keyboard control");
digitalWrite(E1,LOW);
digitalWrite(E2,LOW);
pinMode(2,INPUT);
pinMode(3,INPUT);
//String Buttons[17] = {
// "J2","J1",NULL,"S2","S1","UP","LEFT","DOWN","RIGHT","1","4","2","3","RZ1","RZ2","LZ1","LZ2"};
// // Buttons Nmes
void loop(void)
if(Serial.available()){
// String n = Buttons();
char n=Serial.read();
if(n != -1)
switch(n)
case '6'://Move Forward
advance (255,255); //move forward in max speed
break;
case '8'://Move Backward
back_off (255,255); //move back in max speed
break;
case '7'://Turn Left
turn_L (100,100);
break;
case '9'://Turn Right
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
I just delete the "butten" it isn't a big issue.
but I think a good idea would be to start debugging the xbee configuration first.
What kind of xbee you are using now?
xbee S1/S2 ? or xbee for wifi? even bluetooth bee?
By the way whether you have an adapter to set xbee?
[/quote]
Hello! Grey,
I'm using the "1mW XBee Transceiver Module (Trace Antenna)" and yes, I've already set the rate of xbees to 9600.
Please inform me if there is something I'm missing and I need to add.
Thank you!
Tony
faweiz
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
faweiz
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
faweiz
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
faweiz
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
faweiz
Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
[/quote]
Hello! Grey,
Thank you!
Tony
2013-11-01 20:06:51 Hi Tony
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
Grey.CC
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
Grey.CC
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
Grey.CC
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
Grey.CC
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
Grey.CC
digitalWrite(E1,0);
digitalWrite(E2,0);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
analogWrite (E1,a);
analogWrite (E2,b);
void setup(void)
int i;
for(i=4;i<=7;i++)
pinMode(i, OUTPUT);
pinMode(2,INPUT);
pinMode(3,INPUT);
// // Buttons Nmes
void loop(void)
if(n != -1)
switch(n)
break;
break;
turn_L (100,100);
break;
turn_R (100,100);
break;
case '1':
stop();
break;
else stop();
[/code]
