Forum >Connecting Multiple Devices to Central Bluno Beetle
I would like to connect several PERIPHERAL Beetles to a single CENTRAL Beetle.
I have seen posts claiming this is possible, but the FAQ says its not.
Can this be done? Can this be done without restarting and repairing for each device?
Please respond ONLY with a DETAILED ANSWER. Simply replying "Yes is can happen" etc is not useful in any way.
Thanks.
Thanks.
2021-11-27 02:57:53 The Bluno Beetle is a blue-tooth enabled microcontroller that can be programmed to do anything get cheap resume writing services from making your lights blink, to controlling motors. The possibilities are endless! If you haven't already experienced the power of this awesome device, read on.
fngr28xn
2018-09-22 01:36:23 Hi.
Our current BLUNO BEETLE does not support star connection networking to implement central BEETLE to connect other BEETLE.You can use LoRa MESH Radio Module - 433MHz realize your ideas.
Hope help you.
makermuyi
Hope help you.
