Forum >control 48-V-Coil with the MDV 2x2A DC Motor Controller
RoboticsGeneral
userHead Account cancelled 2018-09-30 06:15:23 3236 Views2 Replies
Hi there,
I wanted to control a 48-V-claw (electric coil) with the MDV 2x2A DC Motor Controller:
https://www.dfrobot.com/product-66.html
The input voltage of the Motor Controller Board can be 46 V. If I provide 46 V, does the output voltage is 46 V too or will it be lower? I ask, because other H-Bridge-Boards with the L298N have a maximum output voltage of 35 V.
Thank you for your advice!
Peter
2018-10-27 20:52:50 do not try an inverter same thing melt down userHeadPic netvoyager2011
2018-10-27 20:51:54 no you will damage all of it 37 v is hot imagine another 11 melt down ! you will fry the CPU userHeadPic netvoyager2011
