Forum >How to make a remote control system via DTMF Module+ GSM/GPR
RoboticsGeneral
userHead Grey.CC 2013-12-17 20:30:44 8532 Views0 Replies
Hello
Last time, I make a remote control LED by SMS via GSM/GPRS/GPS module.
But you know that SMS need a little time to be received. So we can't decide the delay time. We can't make a real-time control.
This time, I will try a new module "DTMF shield".
The preparatory work:
1 DTMF shield
2 GSM/GPRS/GPS module V3.0
3 Romeo board or arduino UNO with motor driver.
4 An audio cable
5 A platform
6 A full charge battery (7.4v)
You can plug these modules on the platform.
Hardware Connection:
1 Plug one side of audio cable into GSM module "speaker". The other to the DTMF module.
2 Connect GSM module driver: Pin 15,16,17(A1,A2,A3)
Sample code:
Code: Select all/*
  DTMF.cpp - TEST code for DTMF library
#include "dtmf.h"
int myDtmf;
DTMF dtmf;
int E1 = 5;     //M1 Speed Control
int E2 = 6;     //M2 Speed Control
int M1 = 4;    //M1 Direction Control
int M2 = 7;    //M1 Direction Control
void stop(void)                    //Stop
  digitalWrite(E1,LOW);
  digitalWrite(E2,LOW);
void advance(char a,char b)          //Move forward
  analogWrite (E1,a);      //PWM Speed Control
  digitalWrite(M1,HIGH);
  analogWrite (E2,b);
  digitalWrite(M2,HIGH);
void back_off (char a,char b)          //Move backward
  analogWrite (E1,a);
  digitalWrite(M1,LOW);
  analogWrite (E2,b);
  digitalWrite(M2,LOW);
void turn_L (char a,char b)             //Turn Left
  analogWrite (E1,a);
  analogWrite (E2,b);
void turn_R (char a,char b)             //Turn Right
  analogWrite (E1,a);
  analogWrite (E2,b);
byte gsmDriverPin[3] = {
  15,16,17};
  Serial.begin(9600);
  for(int i=4;i<=7;i++) pinMode(i, OUTPUT);
  pinMode(15,OUTPUT);
  pinMode(16,OUTPUT);
  pinMode(17,OUTPUT);
  //Init the driver pins for GSM function
  digitalWrite(17,HIGH);//Output GSM Timing
  delay(1500);
  digitalWrite(17,LOW);
  digitalWrite(15,LOW);//Enable the GSM mode
  digitalWrite(16,HIGH);//Disable the GPS mode
  delay(2000);
  delay(5000);
  delay(5000);//call ready
  Serial.println("ATS0=1"); //autopickup on first tone
  // Read DTMF codes one by one and print it on Serial
  myDtmf = dtmf.getDTMF();
  if(myDtmf != -1)
//    Serial.println(myDtmf);
    switch(myDtmf)
    case 2://Move Forward
      advance (250,250);   //move forward in max speed
      break;
    case 8://Move Backward
      back_off (250,250);   //move back in max speed
      break;
    case 4://Turn Left
      turn_L (150,150);
      break;
    case 6://Turn Right
      turn_R (150,150);
      break;
    case 5:
      stop();
      break;
After you have uploaded the code and finish the connection.
Just need a phone call, you can control it.
Fortunately, it works finally. Although it still has some bugs, it works well for the testing.
This project is not only for the robots, but also the home automation. With some sensors, it can do more.
