DFROBOT BME_280 sensor with FireBeetle ESP8266 IOT - Help
![userHead](https://dfimg.dfrobot.com/dfPortrait2.png)
Hello All....
I am very new at arduino projects trying to ease my way into C++ programming language. I felt that I needed to start off small and am failing miserably! I felt a nice Google search and some youtube videos and I would be on my feet and running.
I am trying to setup a very basic BME_280 sensor with a FireBeetle ESP8266 wired as I2C. After loading the DFRobot_BME_280-master example I2C sketch I get this return:
![Image](https://i.imgur.com/Y6xW5PT.jpg)
Sketch
Scan
Any ideas?
SKU:SEN0236 SKU:DFR0489 IDE Arduino 1.8.7
BME280 library https://github.com/DFRobot/DFRobot_BME280
Sketch
Return
* @file basicTestI2C.ino
* @brief DFRobot's Temperature、Pressure、Humidity and Approx altitude
* @n [Get the module here]
* @n This example read the Temperature、Pressure、Humidity and Altitude from BME280, and then print them
* @n [Connection and Diagram]
* @copyright [DFRobot](http://www.dfrobot.com), 2016
* @copyright GNU Lesser General Public License
* @author [yangyang]
* @version V1.0
* @date 2017-7-5
#include <DFRobot_BME280.h>
#define SEA_LEVEL_PRESSURE 1013.25f
#define BME_CS 10
DFRobot_BME280 bme; //I2C
float temp, pa, hum, alt;
Serial.begin(115200);
// I2c default address is 0x76, if the need to change please modify bme.begin(Addr)
if (!bme.begin(0x77)) {
Serial.println("No sensor device found, check line or address!");
while (1);
Serial.println("-- BME280 DEMO --");
temp = bme.temperatureValue();
pa = bme.pressureValue();
hum = bme.humidityValue();
alt = bme.altitudeValue(SEA_LEVEL_PRESSURE);
Serial.print("Temp:");
Serial.print(temp);
Serial.println(" C");
Serial.print("Pa:");
Serial.print(pa);
Serial.println(" Pa");
Serial.print("Hum:");
Serial.print(hum);
Serial.println(" %");
Serial.print("Alt:");
Serial.print(alt);
Serial.println(" m");
Serial.println("------END------");
delay(1000);
So I verified the sensor with a I2C scanner and verified a return on 0x77. I tried to modify the address in the sketch with no help and same return. I also tried to modify the address in the .h library file with no help.Soft WDT reset
ctx: cont
sp: 3ffef3e0 end: 3ffef5c0 offset: 01b0
>>>stack>>>
3ffef590: 3fffdad0 00000000 3ffee568 402020b1
3ffef5a0: feefeffe feefeffe 3ffee584 40203848
3ffef5b0: feefeffe feefeffe 3ffee5a0 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v6000001c
~ld
⸮No sensor device found, check line or address!
Scan
https://playground.arduino.cc/Main/I2cScannerI2C scanner. Scanning ...
Found address: 119 (0x77)
Done.
Found 1 device(s).
Any ideas?
