Forum >Micro Metal Motor connector?
RoboticsGeneral
userHead brianj 2018-10-25 08:22:32 2921 Views1 Replies
We're testing several of the micro metal motors in the FIT0483-related family (https://www.dfrobot.com/product-1433.html), but we need to swap the current right-angle connector with a straight vertical connector for tight testing housing. The datasheet doesn't reference the exact connector or mating connector part number. Can someone please provide that? Pretty please? :)
Thanks,
Brian
2018-10-27 07:17:02 I received a reply from Tech Support, and wanted to share for any future searching.
That connector is the JST 6-pin of this ZH (1.5mm pitch) family: http://www.jst-mfg.com/product/pdf/eng/eZH.pdf
userHeadPic brianj
