Forum >Mini-Q 4WD line sensor problem
userHead adamcrumpton 2011-12-03 19:12:43 7843 Views1 Replies
I have got the DF Mini-Q 4WD and it works great. I am working on programming all of the sensors into a single sketch. So I got the obstacle avoidance working well and I want to add in the line tracking sensors to stop it from driving off a cliff. I got that part working... or so I thought. The sensors print out great values until the motors start and then their values drop close to zero and don't come back up. I hope their is a simple way to read these sensors when the motors running.
And though I am embarassed by it, I will post this cut, pasted, and modified code for all to see:
#define EN1 6//Right Motor Enable Pin
#define IN1 7//Right Motor Direction Pin
#define EN2 5//Left Motor Enable Pin
#define IN2 4//Left Motor Direction Pin
#define Vr 5 // reference voltage
#define FORW 1//Forward
#define BACK 0//Backward
#define IR_IN 8//Infrared Receiver (Digital Pin 8)
#define L_IR 9//Left Infared Transmitter (Digital Pin 9)
#define R_IR 10//Right Infrared Transmitter (Digital Pin 10)
#define BUZZER 11 // control the number of IO pins buzzer
#define LED_RED 12 // red LED lights control digital IO pins
#define LED_GREEN 13 // green LED lights control digital IO pins
const int analogInPin = A2; // Analog input pin that the potentiometer is attached to
//const int analogOutPin = 12; // Analog output pin that the LED is attached to
int count; //Pulse counter
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
float data [8] = {0X00, 0X00, 0X00, 0X00, 0x00, 0xff, 0x00, 0x00}; // store the 8-channel ad conversion value
unsigned char value [5] = {0x00, 0x00, 0x00, 0x00, 0x00}; // five hunt voltage sensor
unsigned char key_1 = 0x00; // number of keys pressed to count 1
void Motor_Control(int M1_DIR,int M1_EN,int M2_DIR,int M2_EN)//Motor control function
//////////M1////////////////////////
if(M1_DIR==FORW)//Set M1 Motor Direction
digitalWrite(IN1,HIGH);//HIGH, Rotate clockwise
else
digitalWrite(IN1,LOW);//LOW, Anti Rotate clockwise
if(M1_EN==0)//M1 Motor Speed
analogWrite(EN1,LOW);//Low to stop miniQ
delay(10);
else {
analogWrite(EN1,M1_EN);
delay(10);
///////////M2//////////////////////
if(M2_DIR==FORW)//Set M2 Motor Direction
digitalWrite(IN2,HIGH);//HIGH, Rotate clockwise
else
digitalWrite(IN2,LOW);//LOW, Anti Rotate clockwise
if(M2_EN==0) //M2 Motor Speed
analogWrite(EN2,LOW);//Low to stop miniQ
delay(10);
else {
analogWrite(EN2,M2_EN);
delay(10);
void L_Send38KHZ(void)//Left Infrared transmitter generate 38kHZ pulse
digitalWrite(L_IR,HIGH);//Set the infrared to HIGH level
delayMicroseconds(10);//delay 10 microsecond
digitalWrite(L_IR,LOW);//Set the infrared to LOW level
void R_Send38KHZ(void)//Right Infrared transmitter generate 38kHZ pulse
digitalWrite(R_IR,HIGH);//Set the infrared to HIGH level
digitalWrite(R_IR,LOW);//Set the infrared to LOW level
void pcint0_init(void)//Init the interrupter
PCICR = 0X01;
PCMSK0 = 0X01;
ISR(PCINT0_vect)
count++;//Counting the received pulser
void Read_Value(void) // read analog value
char i;
for (i = 0; i <8; i++)
data = analogRead(i); // read analog port voltage i
data = ((data * Vr) / 1024); // convert the analog value
huntline_deal();// call subroutine hunt deal
void huntline_deal(void) // Hunt
if (key_1 == 6)
if (data [0] > (value [0] - 1) && data [1] > (value [1] -1) && data [2] <(value [2] -1) && data [3]> (value [3 ] -1) && data [7]> (value [4] -1)) // look at the actual measured value
Serial.println("Set 1");
else if (data [0]> (value [0] -1) && data [1]> (value [1] -1) && data [2] <(value [2] -1) && data [3] <(value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 2");
else if (data [0]> (value [0] -1) && data [1]> (value [1] -1) && data [2]> (value [2] -1) && data [3] <(value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 3");
else if (data [0]> (value [0] -1) && data [1]> (value [1] -1) && data [2]> (value [2] -1) && data [3] <(value [ 3] -1) && data [7] <(value [4] -1))
Serial.println("Set 4");
else if (data [0]> (value [0] -1) && data [1]> (value [1] -1) && data [2]> (value [2] -1) && data [3]> (value [ 3] -1) && data [7] <(value [4] -1))
Serial.println("Set 5");
else if (data [0]> (value [0] -1) && data [1] <(value [1] -1) && data [2] <(value [2] -1) && data [3]> (value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 6");
else if (data [0]> (value [0] -1) && data [1] <(value [1] -1) && data [2]> (value [2] -1) && data [3]> (value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 7");
else if (data [0] <(value [0] -1) && data [1] <(value [1] -1) && data [2]> (value [2] -1) && data [3]> (value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 8");
else if (data [0] <(value [0] -1) && data [1]> (value [1] -1) && data [2]> (value [2] -1) && data [3]> (value [ 3] -1) && data [7]> (value [4] -1))
Serial.println("Set 9");
Serial.print(key_1);
Serial.print("\t 1111111111111 \t");
Serial.println(value [0]);
Serial.print(data [1]);
Serial.print("\t 2222222222222\t");
Serial.println(value [1]);
Serial.print(data [2]);
Serial.print("\t 33333333333333 \t");
Serial.println(value [2]);
Serial.print(data [3]);
Serial.print("\t 444444444444444 \t");
Serial.println(value [3]);
Serial.print(data [7]);
Serial.print("\t 555555555555555 \t");
Serial.println(value [4]);
delay(100);
void key_scan(void) // Scan button
if (data [5]> 4.50 && data [5] <6.00) // no button is pressed
return; // return
else
if (data [5]>= 0.00 && data [5] <0.50) // Button 1 press
delay (180); // debounce delay
if (data [5]>= 0.00 && data [5] <0.50) // press button 1 does
key_1 ++;// key 1 count
if (key_1>= 1 && key_1 <= 5) value_adjust(key_1); // value of the sensor to adjust the hunt
if (key_1 == 6)
digitalWrite (LED_RED, LOW); // red light off
digitalWrite (LED_GREEN, LOW); // Green OFF
else if (data [5]>= 0.50 && data [5] <2.00)
if (key_1>= 1 && key_1 <= 5) // if the key key1 value between 1 to 5
value [key_1-1 ]++;// sensor tracks threshold to distinguish Gaga (adjusted)
value_adjust(key_1); // actual value comparison with
else if (data [5]>= 2.00 && data [5] <3.00)
if (key_1>= 1 && key_1 <= 5) // If the key key1 value between 1 to 5
value [key_1-1 ]--;// sensor tracks threshold resolution and reduction (adjusted)
void value_adjust(unsigned char num) // adjust the sensor values ??hunt
if (num == 1) // adjust the sensor first hunt
if (data [0] > value [0])
digitalWrite (LED_RED, HIGH); // the current value of the red light
else
digitalWrite (LED_GREEN, HIGH); // green light
if (num == 2) // adjust the sensor the second hunt
if (data [1]> value [1])
else
if (num == 3) // adjust the third hunt sensor
if (data [2]> value [2])
else
if (num == 4) // adjust the sensor fourth hunt
if (data [3]> value [3])
else
if (num == 5) // adjust the sensor fifth hunt
if (data [4]> value [4])
else
void Obstacle_Avoidance(void)
char i;
for(i=0;i<20;i++)//Left infrared transmit Send 20 38khz pulse
L_Send38KHZ();
if(count>20)//If the counting is more than 10, there is obstacle avoidance
count=0;
Motor_Control(BACK,60,BACK,120);//Backward
delay(750);//delay for 0.5 second
Motor_Control(FORW,120,FORW,60);//turn left
delay(500);//delay for 0.5
else
Motor_Control(FORW,100,FORW,100);//Forward
for(i=0;i<20;i++)//Right infrared transmit Send 20 38khz pulse
R_Send38KHZ();
if(count>20)
count=0;
else
Motor_Control(FORW,100,FORW,100);//Move forward
// initialize serial communications at 9600 bps:
Serial.begin(38400);
char i;
for(i=4;i<=7;i++) //configure the pin mode
pinMode(i,OUTPUT);
pinMode(BUZZER, OUTPUT); // Set the number of IO pins control the mode, OUTPUT is the output
pinMode(LED_RED, OUTPUT); // set the red LED light control digital IO pin mode, OUTPUT is the output
pinMode(LED_GREEN, OUTPUT); // green LED setting controls the number of IO pin mode, OUTPUT is the output
pinMode(L_IR,OUTPUT); //Set the L_IR pin to output mode
pinMode(R_IR,OUTPUT); //Set the R_IR pin to output mode
pinMode(IR_IN,INPUT); //Set the IR receiver pin to input mode
pcint0_init(); //Init the interrupter
sei(); //Enable the interrupter
data [1] = 0X00; // store the 8-channel ad conversion value
key_1 = key_1++;
Read_Value();// read the value of analog port
key_scan();// scan button
delay(1000);
if(data [0] < 2 || data [1] < 2 || data [2] < 2 || data [3] < 2 || data [7] < 2) // look at the actual measured value
//Motor_Control(BACK,60,BACK,120);//Backward
//delay(3000);//delay for 0.5 second
//Motor_Control(FORW,120,FORW,60);//turn left
//delay(1000);//delay for 0.5 second
// analogWrite (LED_RED, HIGH);
// analogWrite (LED_GREEN, HIGH);
else
Obstacle_Avoidance();//Obstacle avoidance
2011-12-11 17:38:39 Thanks Hector!
It actually was just a case of low batteries. I recharged them and then all of my tests worked suddenly. He stops when he sees the edge now.  Thank you again!
Adam
userHeadPic adamcrumpton
