Forum >Rechargeable batteries for MiniQ 4WD.
RoboticsGeneral
userHead Account cancelled 2014-11-26 10:18:34 4728 Views1 Replies
What type of batteries does the MiniQ 4WD use that can be recharged by the plug on the side of the robot? Also what size wall-wart does it use for the battery charge port and are the wall-warts available for purchase from Dfrobot.com? Thanks for your answers.
2014-11-26 21:18:19 the charge Port is used for 3.7V Lithium Battery?and the charge voltage is 4.2V needed?we don't have the charger .
so I advice you not to use the charge Port?
userHeadPic Joyce8816
