Forum >DFU File available!
PCB ServicesGeneral
DFU File available!
userHead R2D2C3PO 2012-07-31 22:34:51 4764 Views0 Replies
DRC usually makes sure that your board doesn’t exceed the manufacturer’s production abilities. So we supply a DRU file for you to run the DRC. Based on the checking result you can modify your design a little bit to avoid some common problems. Of course, if you have a special requirement of your design, you can also ignore some errors from the report.
DFU Download:http://www.dfrobot.com/image/data/c-pcb-001/DFRobot_Eagle_Rule_v0.4.zip
