Forum >4 Layer PCB stack up (layer height)
I need to know the stack up of a 4 layer PCB: Substrate Height and Trace Thickness
2013-03-09 10:29:46 Hi Mikesters, PCB stack up has many parameter in it. Find out from your PCB manufacture. Below link give information on it.
http://www.fedevel.com/welldoneblog/2011/08/how-to-design-pcb-stackup/
pcb assembly china
larry80
pcb assembly china
2012-10-25 19:38:06 Sorry.For now we just could manufacture the 4 layer boards with 1/2 oz thickness inner layer.
Also I asked other factory here about their production. They can't do this also.....
Lauren
2012-10-23 19:48:05 Hi,
1. The substrate height is depending to the thickness of your PCB order. For example if the thickness of the board you ordered is 1.6mm, the substrate height will be 1.2mm. And the 0.6mm thickness boards will stacked by using 0.4mm substrate.
2. The trace thickness of the 4 layer board on the top and bottom layer is available from 1/2 to 2oz. And the trace thickness on the 2 layer inside the board should be 1/2 oz
Does it meet your requirement?
Lauren
