Forum >IP Code Analog Dissolved Oxygen Sensor
1. What is the IP Code of the Analog Dissolved Oxygen Sensor?
2. What is the duration of the sensor if it is used permanently (24/7)?
Thank you
Thank you
2018-12-25 23:44:25 There is no IP code for this dissolved oxygen sensor.
The period of the sensor could be used depends on the quality of the water, if the water quality is good, the life span could be one year (but you still need to change the membrane), if the water quality is bad, the life span can only be 2~3 months.
robert.chen
