Forum >Help with code
Help with code
userHead moses58 2011-02-24 13:24:37 4926 Views3 Replies
Hi I found this code on your forum.
Could someone help me add a few features?
I have a Romeo All in One, running two motors.
I would like both motors to run forward for 10 seconds.
Then stop for 60 seconds.
Then Reverse for 10 seconds
I'm new to code so this is ifficult for me.
Here is the code:
int E1 = 5;
int E2 = 6;
int M1 = 4;
int M2 = 7;
void advance(char a,char b)
analogWrite(E1,a);
digitalWrite(M1,HIGH);
analogWrite(E2,b);
digitalWrite(M2,HIGH);
for(int i=4;i<=7;i++)
pinMode(i, OUTPUT);
int value = 250;
advance(value,value);
delay(500);
if(value <= 240) value += 10;
else value = 150;
2011-02-26 11:33:01 Thank you to everyone that offered advice and code. I made some slight modifications to add right and left turns, as well as longer stop times. Everything is running fine and as expected. Now this is for the HCR platform with Romeo All in One from DFrobots. It has 3 bumper switchs  and 5 IR sensors. Could someone offer advice on adding these sensors to the code? Example:
Robot moves forward and bumps into a wall. Stop, back up for 2 seconds, turn right for 3 seconds, continue with loop. I know how to stop and turn. I don't know the code to trigger the correction.
With the sensors it is similar but avoidence at 3 or 4 inches from wall.
Here is my sketch it is working great:
[code]int E1 = 5;
int E2 = 6;
int M1 = 4;
int M2 = 7;
void forward(char a,char b) //Move forward
          analogWrite(E1,a);
          analogWrite(E2,b);
void stop(void)                    //Stop
          digitalWrite(E1,LOW);
          digitalWrite(E2,LOW);
void backward (char a,char b) //Move backward
          analogWrite (E1,a);
          digitalWrite(M1,LOW);
          analogWrite (E2,b);
          digitalWrite(M2,LOW);
void Left (char a,char b) //Turn left
          analogWrite (E1,a);
          analogWrite (E2,b);
void Right (char a,char b) //Turn right
          analogWrite (E1,a);
          analogWrite (E2,b);
    pinMode(i, OUTPUT);
  forward(100,100); //Forward at 50% full speed
  delay(10000); //delay for 10 seconds
  stop(); //Stop
  delay(600000); //delay for 60 seconds
  backward(100,100); //backward at 50% full speed
  stop(); //Stop
  Left(100,100);  //Left at 50% full speed
  stop(); //Stop
  Right(100,100);  //Left at 50% full speed
  stop(); //Stop
[/code]
userHeadPic moses58
2011-02-24 20:43:34 [code]int E1 = 5;
int E2 = 6;
int M1 = 4;
int M2 = 7;
          analogWrite(E1,a);
          analogWrite(E2,b);
          analogWrite (E1,a);
          analogWrite (E2,b);
    pinMode(i, OUTPUT);
  advance(200,200); //Forward at 78% full speed
  stop(); //Stop
  delay(60000); //delay for 60 seconds
  backward(200,200)//backward at 78% full speed
[/code]
userHeadPic R2D2C3PO
