Forum >Building the LCD shield.. got a parts question...
userHead Spuzzum 2011-12-02 10:28:39 4501 Views2 Replies
Howdy :)
I'm making the LCD shield from the protel schematic:
http://www.robotshop.com/content/PDF/dfrobot-lcd-keypad-shield-schematic.pdf
Pretty straight forward, but what's the full part number for Q1? It just says "9013".. is it "SS9013"?
http://search.digikey.com/us/en/products/SS9013HBU/SS9013HBU-ND/1047220
Thanks in advance....... :)
2011-12-02 21:39:47 Thank you sir :)
I came across another schematic from another design, and they used a BC548B.. basically the same as the 9013.. they both have a 500mA Collector Current. The SS9013's a Fairchild product, so pretty sure my local shop carries it.. if not both.
Cheers :)
userHeadPic Spuzzum
2011-12-02 19:25:58 Thats an NPN transistor, so the SS9013 from digi should work for you. userHeadPic Hector
